Got replacement fogs in today:
Need to modify the housings so I can fit the HID's in them and just waiting on replacement valence
From what I have seen the HID mod for them is very easy. I thought about it for my driving lights but I'm very happy with the regular bulbs. Do you have the clear covers?
I got my first windshield crack ever today. Was meeting a guy (2014, grille already busted), 30-40 mph. His tire threw up a huge piece of gravel, it hit right in the middle of the passenger's view. Pretty bad knick in the glass, and 5 hairline cracks coming of it. No idea how going that slow with the factory tires managed to throw up a 2 inch piece of gravel. I have met countless people and never had a ding. Hopefully the body shop can at least slow down the cracking.
Edited by kstruckcountry
Took it easy most of the day, but ran to the grocery store when the wife got home to pickup some items for the holiday/weekend/vacation.
I've done it before these are just replacements from the damage the deer did last week. Did have to order a new set of HID's though cause the ones in there the top tab broke.
Just more work that I don't feel like doing lol
Getting the truck ready for a road trip to California. I head out next week and will be towing my wife's Jeep back. Should be a great vacation.
LA area?
Barstow, wherever that is...
about 8-9 miles from me...it's right on I 15 and I 40 merge. theirs lots to do here, just ask Chris... :crackup:
Yea. A McDonald's in a train car and the gas station I use to piss when I go to Vegas
We are definitely hitting up Vegas. The wife has family there. Can't complain about free accommodations. Most I have to do is some cooking & dishes...fair trade to me.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
