Drove my buddies 94 Z to get some tires. Man i forgot how loud a straight piped 350 was, that thing will wake the dead!
Got more stuff out of the storage unit yesterday. I'd like to say I'm making progress but the front half was the easy part, all the heavy bulky crap was loaded in the back half... :banghead:
Noticed my OnStar light is red. I can still call them but they said it can't be checked over the phone and to go to the dealer. Third failure-related trip this year to the dealer. Whatever. I'll call to see if they think it's covered by major guard GM warranty and if not I'll just live with it. Not throwing money into this thing.
Installed headlight flasher on my Sonoma. Maybe people will pay more attention when the pager goes off.
Sent from my LGL86C using Tapatalk
Starting the diagnosing of a Service Air Bag light. It was only coming on for the initial start up of the truck everyday. Now it seems it coming on whenever it feels like it. Hopefully can get it scanned while the stupid light is on so they capture the code. I have a feeling it's a sensor up front but want to be sure before spending the money.
I have a scanner that can read SRS codes.
Wipe down the front fenders and good and tried a new product
Been a Busy 10 days and haven't had time to get online so here is what I did in the last 10 days to my truck... First I dipped the Bowties red it gives it a little accent color to match the hood decals and z71 sticker. Then I got my new tires put on Cooper AT3s 275 60 20. Then I put in a level kit and rear blocks in my buddies 10 Silverado. Also my simple wash job turned into a full on wax job, but took it out in the field today to work with the dog on water retrieves and brought it back home to wash it again. Also was able to squeeze in an oil change for our trip to Milwaukie this weekend, anyone know of anything good to do there? That is all ... Jeez seems like Ive had a lot of time to get stuff done. 20140730_181937_zpst9m41pbm.jpg
IMG_20140801_132320_zpsolvsosi0.jpgIMG_20140801_132422_zpsepjd8wlc.jpg20140810_160140_zpsuiajsmir.jpg20140813_141824_zpsvmb4h7t4.jpg20140813_141842_zps7rilblrk.jpgIMG_231439476894002_zpsjdmwigzr.jpeg
How do you like it? I just bought some blackfire wet diamond, just got here today. Wanted something a little faster for the Mazda since its outside 24/7 now.
When will they make a rock chip resistant wax. Cars in the land of trucks take a beating.
Probably put a fresh coat of Meguairs ULW (been a few months) and then the blackfire.
Edited by SnakeEyes
Day 1 of diagnose of "Service Air Bag" message with corresponding light:
Took to auto parts store, light not on, crap load of codes but none dealing with Air Bag....nuts!
Got home, disconnected battery, waited, then checked every connection I could think of to deal with air bag, all "looked" good.
I did note there is a metal track running under both seats with a sensor looking thing that glide over it as seat moves back and forth.
Passenger side was brand new looking but a little dusty, cleaned it up, looks good
Driver side, the metal rail is covered in surface rust and gobbed up with dust dirt and who knows what else. Cleaned it all up except rust.
Does this metal rail have anything to do with the air bag? Would the rust on the rail cause problems of any sort (air bag or otherwise)?
I will continue to try to get it scanned when the idiot light is actually on so I can capture a code, nothing I can do until then I guess.
Edited by 06SierraZ71
Can't spell today.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
