Nothing. Transom needs work and the whole outboard motor assembly needs to be rebuilt. Water pump took a crap, engine overheated, heads warped.
Sooo I'm assuming no trip??
Still a trip. Im not going. The motor wasnt going to run anyways. We knew thendamahe a couple months ago. The trolling motor is whats going to be used
Finally washed it yesterday.Nice to be able to see out the back window again. lol
I'm doing the valve cover gaskets today (finally!) so if i don't report back with success in at least 7 hours please ban me... lol
I wont ban you, just may show up in Arizona tomorrow morning to slap you though
Yeah they dont...
Chris, when are you driving over to az? By the time I got to my parents house it was getting too late and I couldn't find a d*mn extended 3/8 to even get started. fml
got new calipers an pads on my jimmy. Just need to hook up electric choke on the carb and get 3 tires on and take for a test drive!
Yeah they dont...
I dont really have a reason. On a good day it is 6.5 hrs to Phoenix wkth minimal traffic and going a bit over the limit
Don't start with out me!!! I will be there on the 10th of April!!!!!! :jester:
We're cooling down to the 80's this week so hopefully if stays this way for when you're here Jim.
And this week I'll be buying extended sockets since they're necessary for removing the valve covers. The plan is to do it Sunday morning.
Cooling down ... HA! We haven't had 2 days in March over 50° yet ....
I miss that place! Used to live on 19th & Northern in Phoenix. Best 2 years of my life. Your a lucky man. :cheers:
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,209 Guests (See full list)
