It is only going to be 74 today, but it will be windy
We hit 44.6° today. Friggin' heat wave ... :sick:
The never-ending winter of '15 ... here's a pic I just snapped 10 minutes ago ... still a foot across the yard. More in the woods.
Our garden is under there somewhere ...
Edited by Jsdirt
I wanna take this thing out on a night ride soon. Just installed reverse lights and a 20" light bar last week
Still got my '05 Sportsman 800. It's needed some TLC the past couple years, but still running strong. Sucks that every time I venture off the property with it, it usually results in a police chase.
I really need to move out of the northeast! :nonod:
OOPS ... :lol:post-65085-0-23841100-1427934182_thumb.jpg
Edited by Jsdirt
Yeah my 05 Kawie Prairie 360 is my workhorse. She normally gets the plow hooked up to her. Makes some weird noises from the cvt drive but she still turnin' lol
Nice. Yeah I plow with mine too. In light of the laws around this state, it's been used mostly as a tractor the past 7 years or so. I jockey trailers around with it, move boats, drag trees, rocks, etc ...
post-65085-0-22875200-1427934641_thumb.jpg post-65085-0-24448800-1427934711_thumb.jpg
Put some new sneakers on it last year. Made a HUGE difference plowing. I don;t get stuck nearly as often, but it did result in a busted CV axle and a broken cage inside the front diff ... :drool:
Edited by Jsdirt
Mine has as many highway miles on it as it does off road (farm) use, as long as I am going field to field or checking animals I can go almost anywhere I want on mine. :jester:
EEEEEEEEEEaf4cce5c179fcb0941196c3eadd68275.jpg3486f11a615aa741b544a65f13f1ff58.jpg8d1097128c588a3da2777a04fd72fe44.jpg
BRAPPP! Getting a head start on the weekend I see!
Double flagging it I see! Nicccccce
Edited by 08Z71Guy
Maybe he means both have the flag?
Silver Lake requires vehicles to have the flag up front and quads/bikes on the back Darrick.
I'm planning a weekend trip to SL in June with some friends. Hopefully no embarrassing stuck pics this time. :lol:
Removed the RC 2" front leveling kit.
Than installed the Ready lift 2.25" front kit and Ready lift 2.25" rear lift blocks. Truck sits perfect now. Rear sits roughly .5"-.75" higher which is perfect for me for towing. Before it sat lower than the front.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,290 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
