Went driving around with a friend and lost traction on a trail had to call friends out to push us out. Then got dinner and drove around some more and got pulled over for not switching my lightbar off for a cop and he gave me a fix it ticket for my tint.
Cut some lumber to divide the bed. I swear I had a board in the bed of the last truck but have no idea where it went. I've got a cargo bar, but now with the board, I can keep my gas cans from sliding when I take them to fill up.
Got the Performabuilt 4l60e ready to ship out tomorrow. Kinda miss having it in the lifted truck. Going back in after I get the truck squared away and pass inspection. Getting 37's for it soon and may have to replace to steering gear box and definitely needs sway bar bushings. Should pass other than that
Hauled two loads of mulch. I didn't get any pictures, remembered as I was sweeping out the bed that I forgot to snap one. Got 12 trees and a large flower bed done. Let the weeds begin.
Fix it ticket is no fine it was peeling away so I ripped it off had a cop sign the ticket and I'm re doing the tint Sunday
So no one has heard of a dash replacement being done by the customer?
Guess I'll try to take mine out next week before I order a new one.
Guy on this board did one a few wks ago.
Ryan
I looked at his profiles and his latest post was in January? He said he was going to do it then?
I spoke with him over PM. He was doing some traveling for work
Ryan
Meijer has had like $5 off nd today it was $10 off $50 purchase so I bought 2
I didn't see any oil filters????? You might need to make another trip. :jester:
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
