I installed the rubber brake pedal cover last night, took all but a minute. The new one feels just as thick but is a lot more flexible when bending by hand, and not that it matters once it's installed but it was just interesting.
Up next are the valve cover gaskets and door hinge pins.
Just waiting for the weather to break up here in NH. I need to do my brakes, clean my MAF, and do a full detail. Just the weather has sucked so much,
I had a Gibson catback exhaust and Airaid CAI installed. The next thing will be a Diablew tune in a couple weeks.
Took mine in for scheduled maint this AM. Passed with flying colors. NO pending codes. Everything is great! (So was the Red Robin ghost pepper burger I had for lunch)
They had a (sold) 2015 Z06 Corvette in yellow in the showroom... Gorgeous car!
I want a Z06, but since I have kids a Hellcat might be the best option. I have had people at the cruise in ask where I got the car and they start to flip when they find out it was for sale locally. Might be easier to sell than I thought
Rolled over the 229k mark this morning! :(
Few days ago
Ryan
After a long day contemplating selling her and getting an '06, I began the washing process by cleaning the wheels/tires and the hard to get areas by hand. Not a bad turn of events. lol
I've forgotten to calculate the mileage on this last tank but I'm led to believe that replacing the idle air control valve has led to better fuel economy. Well that and we're no longer near freezing temperatures.
Got stuck and then got pulled over
For what
^^^ wanna hear this story ^^^
John Law loves my truck for some reason. It sucks
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
