It needs some work but I believe I can make a good truck out of it
Haha! If I can make a good truck out of mine I have complete confidence you will yours. :thumbs:
Lol I appreciate the confidence buddy
My IAC valve came in today and I just replaced it. It's a quick 5 minute job including finding the correct star shaped allen key, and making sure you don't drop the bottom screw into an abyss. If you have a magnetic tipped screw driver use it for this job...
Awkward space for the bottom screw.
Tada! The morning start up will be the moment of truth and I'm expecting a much better idle. I've been told this is the solution.
Start up this morning in the lower 40's was marginally better than before, I'm kind of bummed about it. And even if I do get improved fuel mileage I spent $70/80 on the part alone so I won't recoup the cost. And I'm not sure if it was wishful thinking but she did feel smoother overall once she got over the initial hiccups. Edited by white1500
Well I've had to drive here and there all day today around base....dang AC isn't working and it's been in the 80s the last couple of days....very glad I have a white truck and got all my windows to work....
Lucky. Wish we were in the 80's
Looks like an A/C system overhaul in the near future [emoji106]
Yup, under $400 for EVERYTHING. Did mine last spring!
Trade you in a heartbeat...I love the cold and hate the heat. Can't wait to move back to Alaska after I retire in 18 months.
Got the truck to 115 mph today. I have the top speed governer turned off with the inTune. So I just wanted to get it over 99 mph. The truck had more in it, but on a narrow country road with deep ditches and a strong crosss wind, I didn't.
Finally got my truck [emoji120][emoji119][emoji126]!
Might be getting an ar 15 today. Anyone got any expertise on them ? This is my first foray into assault rifle stuff
After yesterdays sketchy cold start today was the first perfect start in years!! No hesitation at all and I didn't need to modulate the throttle. Maybe its because of how I'm used to warming her up but maybe a few hundred rpm's more would be better, instead of today's 1,000.
What rpm's do those of you with a <2002 gmt800 see on a completely cold start??
it varies but it's usually around 1000 rpm give or take and then it settles down once she's warm
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
