Drove my boy to his Cub Scout meeting yesterday. It was either raining or training to rain ALL weekend so didn't do a thing other then drive the truck here and there.
Did some heavy towing. I had to use all the torques and ford a lake. Sure worked it hard
  • Like 3
Are your springs rated enough for that?
Same springs that came in your truck. Didnt even squat with that load. Had to pull up the wet/slick incline in 2nd.
Fixing to go get tune up supplies. This thing needs it bad!!
Edited by zach1990
Not too bad. Since my road has been so bumpy lately I've kept my rear end weighed down with a Radio Flyer and a bag of trash for the extra traction. Man what a difference it makes....
Just started replacing spark plugs 333k miles on these...ca6d28a76f3fd1cb000fbbb36b3fb9bf.jpg
That thing has been abused...
It needs some work but I believe I can make a good truck out of it
Soak em in some Coca-Cola I bet it will clean em up real good lol
My IAC valve came in today and I just replaced it. It's a quick 5 minute job including finding the correct star shaped allen key, and making sure you don't drop the bottom screw into an abyss. If you have a magnetic tipped screw driver use it for this job...
Awkward space for the bottom screw.
Tada! The morning start up will be the moment of truth and I'm expecting a much better idle. I've been told this is the solution.
My intermediate steering shaft got clunky all of a sudden today. I guess I'll replace the bearing and shaft.
Just did that this weekend in my Tahoe, the job is harder than it seems. Really tight fitting stuff and really tight working quarters.
I don't really feel like dropping $200 on the Borgeson shaft right now so it may be a while (summer). I'll have to take a closer look at how to get to the upper portion. I may do a new brake pedal "shim" too while I'm at it.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
