Time for 37's
Now that you mention it the 35's do look small now.
Edited by Btuggle88
Just dont show the wife the credit card statement
Don't really want to start a new topic for this. But hope Chevrolet &/or GM marketing people keep this up
Whether they use Dale Jr or a farmer out in Nebraska or what not. The heritage theme in my opinion, just works.
Agreed. The commercials they had for their centennial (many not broadcast, just on YouTube) were some of the best they ever had. Chevy has significant heritage in America and that resonates with a lot of people.
I know a huge part of their marketing outside of fullsize trucks and SUVs is getting buyers from the imports into a GM showroom but honestly until the import humpers over at consumer distorts (reports) and similar publications start being honest in their evaluations, the American brands won't get to them.
Went sledding
Ryan
Your doing it wrong. Should be pulling it behind the truck lol
  • Like 5
Is your travel limited at all by the 35's? They look good to me.
No they work fine they just look small now that the truck is lifted.
Get some 37s you will not regret it! There is a Facebook group for SC that has people trying to trade tire setups all the time. You want the name?
Truck looks good!
Truck looks good!
Sure send me the name.
What I meant is do you have any rubbing flexing?
No rubbing anymore they work fine, I'm used to watching my turning and now I have to learn I can turn all the way again. Edited by Btuggle88
Someone in a 2500HD drove down the block doing that today. Real safe
Ryan
Ryan
I never said it was safe
Did some backwoods driving with my dog. 53ca4191eb72816be27ce362aa13eb0c.jpg10f5f2aefd9b42fd85049862fa2cf7f1.jpg
Sent from my iPhone
Nice photos & cool dog. Have similar in color blue/grey pit mix too.
My wife helped me clean the crap out of the interior yesterday. We managed to get all of the stains out and even took out the air vents to clean them up and also went as deep as I could into the ducts themselves. Its needless to say that its a more inviting place now!
We then drove up to Black canyon (town outside of phx) and had some amazing pecan pie. Definitely a good enough reason to stack on another 60 miles.
And I'm pleased to see that she hasn't used any oil so far. Its already been about 1600 miles on the castrol 5w30 with practically zero knock/lifter noise on cold start ups. Very pleased!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
