Explain what part of electronics I don't understand? I don't get where your going with that claim ...
Sure, if you raise compression to compensate for it's lack of "bang". There is no free lunch - it the truck is optimized to run on E85, then it is NOT optimized to run on regular unleaded. No fancy wiz-bang electronics can change the laws of physics.
I still call b/s on that claim. Unless I saw back to back dyno results using E85, and then unleaded, or vice-versa, I don't buy it, because it's not possible without engine modifications. So in your world, gasoline beats diesel. Just because the internet & GM might say so doesn't make it true. I don't see Freightliner or Peterbilt scrapping their diesel programs any time soon ...
Go ahead and tell me some facts of E85 on fuel injected motors controlled by a computer. Maybe you should "look that up". We can spin this however we want for both of us to be right. The point is, there are benefits to E85 for horsepower and torque numbers, especially if tuned correctly. There are also engines were there are absolutely no gains to be made, you are correct.
WHAT DO YOU WANT TO KNOW?
My truck IS computer controlled, and it ABSOLUTELY loses power and mileage on E85. Are you telling me otherwise? :dunno:
Edited by Jsdirt
And who is saying gas beats diesel? Totally different circumstance. Your arguments are shit.
You are , by telling me that E85 is more powerful than gasoline. Its NOT TRUE, never was and never will be!!
You are making yourself look stupid, I am starting to get embarrassed for you. Please stop, you're wrong
Don't try to be smart with words because you're losing. E85 may have less energy density but it ABSOLUTELY allows engines made to run it to build more power. Especially turbo motors.
Edited by MikeNH
Really????????????????
"1 gallon of E85 has 73% to 83% of the energy of one gallon of gasoline (variation due to ethanol content in E85"
http://www.afdc.energy.gov/fuels/fuel_comparison_chart.pdf
Do you need more links on this? Just let me know. There are thousands out there .... just look for yourself.
YES - when the engine is OPTIMIZED TO RUN ON ALCOHOL it is NOT OPTIMIZED TO RUN ON UNLEADED. Like I said before, there is no free lunch.
Try to run regular unleaded at 14:1 compression and watch what happens ...
My 2011 ran fine on both. The new GDI trucks run fine on both.
hahahahahah WOW, you're on your own pal..............
Here;s some more proof for you E85 lovers, straight from my own window sticker. See the note on MPG for E85?
These newer motors are optimized to run both e85 and unleaded
No one is debating the difference in energy density. But that is only one factor. There are tons of things that effect power building. Manufacturers can make more power on E85 and run fine on 87 too. Fact.
    d.lowrey
    d.lowrey
  • Who's Online   3 Members, 0 Anonymous, 4,376 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
