19 minutes ago, Black02Silverado said:
I got this one  YI.  I got it when Amazon had it down to $25.  I have another one in my Cruze.  The fuse I hooked it to turns off the power as soon as you turn off the vehicle.  My wife wouldn't want to deal with having to manually turn it off.    I'm looking at getting a Blackvue front and rear for my 2019 with the power backup.  Been keeping an eye out on Ebay.
Nice setup there. I've been wanting one for a while now ... but I'm afraid it will incriminate ME more than other drivers, LOL. :D
Same here, just have to remember to get rid of the SD card. :)
I hear that - I remember living in Phoenix, none of the old cars had any rubber left - seals, weatherstrip, tires - all blown out! [emoji38]
Like I said, that doesn't look half bad. Since it's only 3 years old, everything should come apart no problem - just a little tapping with the hammer once the bolts are out. Might need an impact for the bolts (or a cheater bar for the ratchet), though. Side load the caliper to squish the piston in a hair, and it should come right off. Should be able to get a few more years out of the components if you lube up the areas that need it real good.
Salt kills metal fast ... but exposing something to salt, then parking it on dirt or grass is a sure way to DESTROY stuff. Exactly what happens with ocean going boats in the South, and occasionally driven cars in the North in winter.
Usually on boat trailers, only one axle has brakes. You might only have to deal with 2.
I've only owned it 2.5 years, those brakes have probably been on there 7-10+. Since it's a triple axle and the trailer is rated for I think 21k I hope it came with brakes on 2 of those axles. A lot of weight to slow down with only 1 axle. Pretty sure it has 4, I think one of the brakes on the middle axle was the one that wouldn't disengage when backing. It's been 2 years I forget crap from 2 hours ago.
As far as the dash cam goes, it's only incriminating if you get caught. Otherwise it's great to show people how stupid people are. Maybe one day I'll upload the vids to YouTube and share them here. Right now I just put them on FB so my friends can laugh or be shocked.
Sent from my Find7 using Tapatalk
Ahh, 21k will definitely have brakes on ALL axles. That's a big boy! Never seen one that big before around here.
Oh I'd have alot of great footage around MA. It's a non-stop circus up here. You'd think you were watching a Russian dash cam vid. :lol:
In the shop so far today, I couldn't fix 2 Dodge FOBs, the transponder in one of them was cracked in two pieces and the other one was dropped in slush last winter. Salt and gold don't get along very  well and salt always wins.
Then refurbished a 2004 Avalanche cluster in blue.
Oc8xsYt.jpg?1
On 2/4/2019 at 8:21 AM, Jsdirt said:
That is bad, I have never lived in that part of the world, but dang!
And that's one of the better looking rotors I've seen ...
I sure do miss AZ! I bought my '72 El Camino there - everything on that car just came right off, even after nearly 4 decades on the road. Up here, once the vehicle hits year 2, the torches come out, especially on the new stuff. Today's metal is complete garbage.
Just finished an other 2004 Silverado cluster LEDed in blue. Aside from the mileage looks pretty much like the one I did yesterday.
cR1BCoF.jpg?1
It's almost getting boring...
Took a photo of it at the park after I got done jogging.
Still pondering mud flaps for the winter. Do they help at all? And can I run front ones with the auto running boards?
They cut down on where the mud and rock chips end up, but don't entirely eliminate it.  I had one rear one get tucked under my rear wheel somehow - probably some punk kids - and melted half of it off.
Looks like plenty of room up front from here.
Thanks man! I may give them a shot.
I got the Suburban all cleaned up and waxed.  Even cleaned and conditioned the leather interior, pulled the Weathertech's out and scrubbed them. Man what a job, I forgot how big that thing is.
  • Like 3
  • Haha 1
POS Toyota. Wife freaked out rear drivers side door wouldnt open. Come to find out the fuel door hinge broke causing it to remain ajar a bit setting off the door sensor. They don’t sell a painted replacement so I had to buy a new door assembly and paint. [emoji35]
Top part that holds the hinge pin cracked off. Common problem from what I read
Found out I have another recall for the pass side airbag sensor as well.
[emoji35]
Ryan B.
Welcome to 21st Century QC!
I just fixed one last night on a '07 Lexus RX350 - looked exactly like yours. It was rubbing against the paint at the lower inside part as you opened the door, making a horrendous noise.
The $50,000 vehicle was here, because the ignition switch seized solid, leaving the woman stranded. Yet another pattern failure on these & Toyota ...
9 minutes ago, RyanbabZ71 said:
POS Toyota. Wife freaked out rear drivers side door wouldnt open. Come to find out the fuel door hinge broke causing it to remain ajar a bit setting off the door sensor. They don’t sell a painted replacement so I had to buy a new door assembly and paint. emoji35.png
Ryan B.
Forget that, just bypass that door switch and call it good.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,228 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
