Refurbished a 2005 Mustang cluster with new stepper motors
WmIKhf2.jpg?1
Washed my truck and replaced the wife’s fuel door
Make shift paint booth in my office at home
Used 10/32” rivnuts
Ryan B.
  • Like 3
Ryan B.
Did you clear it? If so, don't forget to compound in a few days to get the gloss up.
Edited by SnakeEyeSS
Makin’ kindling.
  • Like 3
Took the kids to a concert, in San Diego, on Saturday (Panic At The Disco), and drove in the snow on the way home, yesterday.
Today, I took it in for its first scheduled maintenance & oil change, at 0900, and was a hour late for work, because they were having problems re-flashing the software to get rid of my backup camera not being able to dim.  They had finished the software load, and had put it in line to be washed, when I first asked what was going on, that was around the time that I had to leave to be at work ON TIME.  They finally gave me my truck back to me, when I needed to be clocking in.  Needless to say, I am NOT happy about them causing me to be late to work.  It WILL reflect on their customer survey.  :mad::mad::mad::mad::mad::mad::mad:
  • Sad 1
That would've pissed me off, too. When other people cost me money, I become less than friendly ... :fume:
Diagnosed my oil pressure gauge that freaked out on me today. Picked up replacement parts and will repair the issue this evening. It was also cold so My tires were a little low on pressure. Resolved that as well.
20190219_062023-1_1550604725167.thumb.jpg.02513ddb3a5a5f234a10c96b6eb8af3a.jpg20190219_062340-1_1550604724929.thumb.jpg.67973b0dfe18f75d6b706d001401e825.jpg
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
