Oh I believe it i just know I need a clutch and piston right now I'm wondering what else I should toss in
How deep is budget? For longevity, definitely upgrade the sun shell
And get a bigger stall if you plan on a cam later.
Go with the 65's Sprag, decent clutches and steels, and a TransGo HD2 shift kit
The 2006 sun shell is supposed to be pretty good already.
I've heard the same and totally forgot she had an 06 lol. But $1500 can get you a mildly built trans I'm sure.
I'm going to save and add that to my tax return in feb I've heard alot about trans go, hd shift kit sounds like a good idea, and regardless if it's good or not I'm upgrading my sunshell
Yesterday: Took the kids to an appointment and then picked up my PS4. Luckily off this weekend so I can actually use it. Think I'll dump my Xbox One preorders. Not enough free time to warrant it.
Edited by SnakeEyes 325is
I work in the fiat 500 shifter assembly cell at
Work this is what I left behind on the knob camera for first shift.
Sent from your truck
so you work at a Fix It Again Tony plant ??? :crackup:
Edited by desrtrat
Spent the first half of my day running errands and the second half with my friend in his 2014
Sent from my Samsung Galaxy S4 using Tapatalk Pro
Went to goodyear to get a new tire. Ran over a fencepost hunting, $370 later I have one new 265/70/17 Duratrac. The rest of my tires are about 6 months old.
Had a good rain this evening. The tires new Goodyears perform well in the rain
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
