05 Kawasaki Prairie 360 4wd. This thing has been driven into the ground and worked hard. Plowing 2 foot of snow twice in one year is pretty extreme on a quad. Im surprised it hasn't blown up yet
I havent seen my truck since I got here. These guys just want to take cabs
Expensive but so much easier!
Washed with dish soap
and after that.....?
I decided to do a 3 day detail instead of doing it in one day first day was interior cleaning 2nd was cleaning exterior with dish soap to remove wax and today I clay barred buffed out some bad spots, out put protectant on the plastics and hand waxed entire truck plus wheels here's the result
I miss mine. On a work trip and I have a Mazda 5. Hate it. Seat doesn't go back enough so driving is crazy uncomfortable.
Sold mine... yep. Have thought about it before, but didn't wake up this morning planning to be truckless by the end of the day. I got a nice offer. Now looking to possibly get a 2500 or 3500 Duramax. Not getting another 1500. I have the original 17"s with goodyear tires if someone local is interested. They are the 6spoke. Tires have about 10k miles of use on them. They still have tpms in them. $500.
Edited by SouthCo
At Planet Hollywood with Zane and Josh
Sent from my Samsung Galaxy S4 using Tapatalk Pro
We took my Sierra to Planet Hollywood to eat at Gordon Ramsay's Burgr
So while the 3 of us were in the truck, it hit 132,000
good choice... are you looking to get a 13' or a 14' 2500? if you could wait a few more months you should be able to get a killer deal on a 900 2500.
Picked my truck up from the dealer again. 3 days same problem. Will not quit vibrating!! 2012 Sierra 1500 8000 miles. I should of stayed with the 03 duramax. I will never buy another 1/2 ton again.
Constant vibrating or while on the brakes? I wonder if the factory was suppose to put the hydraulic cab cushions/mounts but didn't. I think those were meant to solve some kind of vibration issue
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
