Too bad they are now obsolete
That's the way my luck runs, now that I put it on my truck I'll probably trade it next week. Lol
How so? The site is still around. Doesn't matter the style of the decal
Ryan
Bought a new tail light to replace mine that is cracked
Ryan
I picked up some new to me XD wheels!! Think that I am going to be like all the Northeners and have a winter set of wheels and tires and a summer set!!! :jester:
Way to stereotype I take offense to this haha
Ryan
Filled it up and stopped by Walmart and bought some McGuires leather wipes to clean my seats and some applicator pads to put some tire dressing on, wipe on only never spray. I never realized how many women and girls were into trucks until I went into Walmart today, in the parking lot a girl got out of a Sierra with a 4" lift and black rims and then there was a young girl inside buying mossy oak floor mats and seat covers for her truck.
They are a rare breed nonetheless lol
Sent while in 'Murica...
My daughter is a 25 year old Scientist. She's been shopping for a new Colorado/Canyon, but she wants a Cyber Gray Z71 4x4 Colorado Crew Cab Long Box. We found a Short Box equipped exactly like she wanted last weekend. There was a dealer that had a long box exactly like she wanted, but it had a damaged drivers door that they had to repair. She passed on the phone, but was going to look at it on the weekend. They sold it on Friday. Not many on the lots.
Going to check into dealer locating one for a trade, or possibly ordering one if that don't work. They are on constraint right now. I think they are busy building dealer orders, and 2 wheel drives. It wouldn't let me build a 4x4 the other day.
The leftover 2014 1500's have some good incentives if you like red and white.
My dad backed his truck into the pond :crackup: Had to pull him out in my truck. Truck didn't even struggle a bit
Edited by GrapeSoda
Won't ask as my cousin and I have driven a riding lawn mower into a lake
Ryan
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
