Hopefully he doesn't notice lol debadge the driver side so far ran out of time,light ... i should've asked if it was ok to do it... 480442274f048484f54217a68271f770.jpg20646f84a91daadbfc5499a7495f576b.jpg
Got some new toys in for the truck today and ordered my new KO2's (back ordered till mid march)...
And I gust cancelled my order of KO2's, I found a set of brand new Grabbers on KIJIJI for dirt cheap so I'll run those for a few years instead...
I could make it work. Cant have a receiver ball in it.
Atleast it'll fit. Better than being outside.
I was bored waiting for the Fiancé at her college class today so I used the computer lab to print off everything I could find on my truck from the GM Upfitter website.
I was about to use the 29% off coupon at AutoAnything today. But then I learned the engagement ring I bought my gf will cost $400-500 to resize :(
Sent from my SM-G900P using Tapatalk
What!?!? Why?!?!
What!?!? Why?!?!
Because she wanted a really expensive ring lol. I ended up getting a sweet deal because someone bought it and plans fell through. Only downside is the size was 5 and she needs a 7.25. But even with the resize fee I'm still over 50% including the diamonds too.
Wow! Well as long as she's happy you'll be happy lol!
Oh yeah I got lucky. I was able to purchase to her dream ring...may still buy some auto parts tonight lol
Hold up, 29% or did you mean 20%? Lol
Likely 29 since it is february 29
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,215 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
