20% I just checked lol
29 made sense
My new to me 86 Scottsdale 305 4x4
Sent from my SM-G925V using Tapatalk
Nice! What are your plans for it?
I'm betting: Jack it up high.
A Silverado in front of me had its trans explode in front of me on the way home. Got the fluid puke on dash cam.
The thing is the moron was in the left lane (on a highway) while having issues(didnt realize it was HIM until it was too late, all I knew was there was some smoking up ahead), and chose to stay there. And so he got stuck there when it gave out, causing a traffic jam. He had many chances to move over but chose to be stupid.
Edited by SnakeEyes
Did it cause any damage to your vehicle?
No, just had to straddle the puddle. I don't think anything mechanical fell out, looked like it just blew some seals out.
But I had some kind of clear liquid droplets on front of car that smeared when touched. Not sure what it was, but wasn't water, so I did an "emergency detail" as soon as I got home. Not sure if it was from that truck or from another.
Atleast there's no body damage. Definitely some bad luck getting behind him though.
That'll be me one of these towing runs ...
When I was living in Cali I had the front bushing & seal in the tranny blow out at 115mph on one highway near Fremont. This prick in a Mercedes was riding my ass, so I stuffed it to the boards to put some distance between us. Luckily right as he got up on me again, the seal let go, COVERING his car with tranny fluid. I saw his wipers go on, HAHAHAHA! Ended up making it to my first day of work, 10 minutes late. Got yanked by CHP for blowing a red light because I couldn't stop - if I did, I wouldn't have been able to get moving again. Had no fluid with me. As soon as I saw the cruiser lights, I killed it and coasted. I was 500' from my new job, lol.
NICE Scottsdale Sarah! Thing is mint! Those are impossible to find up here anymore ... and if you do find one they price it like it's a '69 Chevelle SS.
Not doing anything to it right now no it's not getting a lift just an extra truck for when reds down for winter months.
Had to tow today. The new tires did well. 905c7c29cc3b57330973f437b57a001e.jpg
You'll be cruising in style no matter what time of year.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,244 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
