Can't wait to slip back into another 800 as my weekend warrior truck. New truck may be quiet but I miss my 800 and the simplicity of working on it. Plus I'm not scared to break something cause it's cheaper to repair
Just more reasons I love mine.
I really like the layout of the 800 interior, actually.
I do too, it's just that the materials aren't the greatest.
135e53a1f6b6f4d993e415b4a5b1e555.jpg Took my quad into the city yesterday morning for its first service then went quading afterwards and got it stuck. On another note will leaf springs out of a 2009 2500HD bolt into my truck I'm sick being flashed while hauling in the dark.
Yes, need longer u bolts though
I think airbags are easier, even possibly cheaper ...
Looks like you guys didn't get much show up north either. I'm very happy about the lack of snow down here. :)
Been fixing brake lines on the 86 past couple days.. so frustrating. Also ordered completely new brakes in all 4 corners.
Sent from my SM-G925V using Tapatalk
Edited by SarahsGMC
Looks fun. I'm ready to go riding myself. Hopefully spring comes soon.
Got it done and went for a cruise
Looks great. Did you use a photo edit filter on that pic? The colors really pop, even the trees.
Edited by SnakeEyes
Yea instagram
Edited by SarahsGMC
She's a beauty Sarah! I'd cringe driving that in the salt, though. The 80's trucks rusted away pretty fast.
I see the new trucks went the Ford way with the 0w-20. Stuff is like water. It's a wonder it even lubricates, lol.
Idk for sure... it's a new motor for sure told my brother to drive it very hard for the first week. And change it to full synthetic oil and magnetic drain plug in it. Then just change it when at 10% on the oil life system
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,012 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
