Sorry man - that sucks big time. At least from here it looks like you'll get out of it relatively cheap - just bumper and plastic, and probably all the brackets. Just a little different angle and it would've cost thousands.
Sorry for your truck but thanks for taking that Jetta eyesore of the roads for us.
You're mostly OK, that's all that matters. Insurance will hopefully take care of the damage.
Got to drive a F150 box truck and delivered out of a golf cart today. Fun times indeed. You'd think with all these people needing jobs that people would show up to the job they've got, I guess not. Oh well UPS is always hiring.
Sorry to hear that Chris, glad no one got hurt.
Got some scary news today. Got my reminder postcard for the airbag deployment module in today so I gave my dealer a call and he said "will only take 15 minutes, bring it on by right now". So I took it down there reminding them that my airbags have previously been deployed (recall states to replace module if previous deployment has been detected), side curtain only no frontal. He said the body shop should have replaced the module and they just needed to update it. All good right? Nope. Waited about 15 minutes, he came over and it seemed like the truck was ready so I was about to stand up and follow him to his desk when he started spewing the bad news. Said the tech hooked the computer up to my truck to fulfill the update and, wait for it, said the airbag module was not communicating with the computer in which he said it wasn't communicating with ANY of the airbags. So basically I've been driving around for 3 months without airbags.
I'm pretty furious with the body shop and the dealer, considering the dealer had possession of my truck for a week or so to diagnose an issue with my park assist. Not sure what to do anymore. They didn't want me to take it, for good reason, and put me in a WT model 2015 Silverado. He said the module is on backorder, didn't even give me a time frame of when it'll be in.
Not sure what to do anymore, even my service writer who I have a great relationship with said that I've had the worst luck with this truck. Starting to contemplate on trading it in.
Nice thing about this WT truck is it rides way better than my truck, a lot quieter, fit and finish seem to be a lot better than my truck (no weird creaks so far), and I have a 6.5' bed now lol
Modules .... I'd like to beat GM engineers over the head with them.
Wait now something doesn't add up here. If the SRS module isn't communicating with the ECM their should be an SRS light on in the dash. Also if the SRS isn't communicating with the seatbelts and impact sensors their should be a U communication code set and Check Engine light should be ''ON''. I think they screwed something up when changing your steering wheel airbag and they're bull whipping you.
Edited by Coby7
My front airbags never deployed only the sides. I'm not real familiar with how the whole system works I'm just spewing what he told me
You do have some pretty bad luck with trucks. Hopefully they'll get yours fixed up.
I think someone is yanking your chain, If their controler code reader can't communicate with the SRS module this means the ECM can't either because they're on the same GMLan communication circuit. If this is the case and if the ECM isn't setting a code it would mean that the ECM is also bad, which I doubt very much. Something is just not right with what they are saying.
Meanwhile enjoy the work truck.
Edited by Coby7
Think my tune could be interfering with it? Never have had an issue before, don't see why it would cause one now
A tune just modifies the parameters in the data matrix, it doesn't affect communications between CPUs.
Yeah that's what I figured. Idk, as long as they can fix it I'll be happy
Left 10k Fifth Wheel in fargo and truck sure spinny...stopped bought fuel and 85 gallons later, no more spinny.
Finished up a customer/friends truck with her new headlights
https://vimeo.com/193566162
Sent from my SM-G925V using Tapatalk
Was that vid in real time? If it was, it would be a riot flipping those lights on in this state - you'd have 10 troopers box you in on the side of the highway claiming "impersonation of a police officer". :lol: That would make a fun Youtube video. :D
They come out with tape measures if you truck is anything but stock height ... and spot you 10 miles out if ONE plate light is out up here.
They need the revenue for all their social engineering programs. :sick: But I digress ...
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
