Appearance Pkg problems already..
Mines a 08 with zero chips. I used 3m tape on the lower rocker panels, front bumper, front of the Hood and even the headlights.
check out this http://drcolorchip.com/
I just ordered some because my son put a scratch in the rear quarter on my truck (not bad but noticable for me)
Mine isnt to bad but I do have some chips which are to be expected. Unless you let it sit in the garage 100% of the time chips/scratches are going to happen
Can you keep us posted on how that stuffs works for you? I've been thinking about getting some of that for my wife's car.
Yep going to use maybe this weekend
Ryan
Ryan
It would be great to see before and after pictures
I will do some. I tried some before pics with my iphone and it was hard to tell. I only have 3 or 4 small chips currently on the front bumper. I plan on working on it tonight or tomorrow afternoon.
Sorry I haven't provided an update. Pictures didn't come out very well. The chips filled in ok (similar to touch up paint). It didn't fix my scratch I had. Overall not super impressed compared to the touch up paint pens but it works to fill in chips. If you do mess up you can fix with this kit unlike the paint pens. I would rate it a 7 out of 10
Ryan
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
