Finally Took the BlackBear plunge
  • Replies 54
Corey what have you noticed different with your truck.I would guess you have your BB tune installed now.
I was thinking the same :dunno: No tune yet. If I had to guess they probably were/are busy with the tune session they were getting ready for. Bad timing maybe.
Gas America off 267 and 10th street in Avon is now speedway
E85 was 3.07 today
Ryan
Wish I would of seen this. I overpaid quite a bit and paid around $3.60. I guess the prices on E-85 from station to station must fluctuate a lot more compared to gas.
Best of luck with it. Im anxious to hear about your results
Thanks! I will be sure to post them. I forget sometimes this stuff takes time :cool:
It depends on if they are buying it or the refine it themselves
Ryan
Corey, I see you in the queue. Unfortunately, the multiple emails you sent, kept us from seeing the files right away, so that delayed us putting you in the queue. You will probably see the files tomorrow.
I guess probably is better than never. Seems like that email filter needs tweaking ;)
Thanks Jenna
Sadly, it is how every filter works, keeps things streamlined though, when we need to reference all details from one customer.
Thanks Jenna, I'm a little impatient at times. I appreciate your responses.
Just wanted to get the word out that I did in fact get my tune files emailed to me and installed yesterday. Since it's just the initial tune I won't say too much but so far I'm impressed. I'm also in the process of switching to E-85 and only on the beginning of my 2nd tank. So I believe my ECM and TCM are both under relearn overload right now.
The good so far:
At WOT this thing sounds like it gained a couple more cylinders. The 5.3 just sounds PISSED. Shifting under WOT especially under highway conditions seems a lot more positive, and more inside the powerband when doing so. Keep in mind my truck is totally stock other than the tune.
The bad so far:
AFM is still engaged (or at least DIC says so) and driving in the city from 0-40mph unless I'm flooring it is still kind of meh. Taking off from a stop light doesnt give me any tire smoking wheelspin but I am now feeling the wheelhop people talk of. My only concern is the G80 I've got back there in the rear. Some guys were talking about chirping tires from the 1-2 shift...some even into the 3rd (somewhere I read that, may of been a 6.2 guy) but none the less- performance is my primary goal.
So- take this all with a grain of salt fellas. I do think its worth the money and the fact that I can address these issues with Justin and work on it makes me feel 100% satisfied.
Have to ask though,
Did it cross through anyones mind during the reprogramming that "...man...I hope this truck starts afterwards.." yeah that was me. I paused and said a prayer. :lol:
Just got mine in this morning. And sent the follow-up log just now.
Definitely notice a difference. More response and more snarl from the exhaust. Cant say with absolute certainty that here is a true "performance" boost without a real way to measure but I am sure there is some.
The detonation problem I was having is much better. Next tank I am going to switch to 89 octane and see what kind of difference it makes. Mileage seems to be the same and might even be a little better since I noticed the V4 on the highway going to work seems to stick around more but I will have to go through a few tanks to know for sure.
Overall, happy with the results. Wasn't cheap but I would do it again. Cory, yes, I wondered the same thing - not so much would it start but would it blow up when driving down the road!! :omg:
Ernie
Thought I would post a follow up to my previous post now that I have driven it for a little while.
I have to say, the more I drive and get use to the tune the more I really like it. At first I was focused on performance of course like everyone else which there is definitely more of. But the thing I didn't appreciate was just how "smooth" everything runs now. The powertrain just seems to work better. The tranny shifts much smoother even when just going from park to drive - no more slight bump. The engine seems to start better as well - before the tune the exhaust would sound kind of muddy with a cold start until it warned up but now it purrs right off the bat.
The detonation problem I was having was mostly gone when I installed the tune. It is pretty much completely gone now that I switched to 89 octane. Gas mileage is about the same as it was before the tune but it will still take a few more weeks before I really know for sure.
Overall, really glad I did it and wouldn't hesitate to do it again. :driving:
Ernie
Thought I would update my experience as I've got the tune right where I want it now.
Justin reread the logs after the tune I installed and further made some adjustments. AFM is now disabled and the truck is now wanting to break loose in first (it nearly does) and I'm finally hearing the chirp of the tires when it shifts into 2nd. Veryyy cool. First time I've ever experienced that in an automatic. At WOT the truck is PISSED. Stock exhaust seems like it opens up and quiets right back up when I let off.
I was a little unsure if this was all worth it in the beginning but I'm very satisfied with my experience. I can't really reflect on any MPG gains because I switched to E85 and I'm only on the 4th tank now. Besides, I've been a little more into the pedal than usual so I won't expect much. I plan to take her to the track just to see what she will run. Now to decide what I'm gonna do next..... :devil::thumbs:
I was a little unsure if this was all worth it in the beginning but I'm very satisfied with my experience. I can't really reflect on any MPG gains because I switched to E85 and I'm only on the 4th tank now. Besides, I've been a little more into the pedal than usual so I won't expect much. I plan to take her to the track just to see what she will run. Now to decide what I'm gonna do next..... :dvil: :thumbs:
Hi Corey,Frank here i am up in canada and have the identical truck to you.Got the BB tune and i you sound pretty happy with your tune.I am not yet .Top speed cutout is gone but not much else from what i see.Can you do a o-60 time and then a o-100 time then we will compare.
Keep in mind, no two trucks are alike (you have engine, driver, modifications and gas quality/octane to contend with). Did you get an AutoCal tune? What octane are you running? Have you cleaned your MAF and throttle body?
After the computer learns the new tune, the settings should definitely be noticeable.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
