AT tires that dont throw rocks
magstar67
I am looking at new tires, I drive on gravel roads a lot and dont want a tire that throws a lot of rocks. My original Bridgestone Dueler AT's were terrible for throwing rocks onto my truck.
I am looking at BFG All Terrain KO's, Nitto Terra Grapplers, and Goodyear Duratracs. I like the BFG's but have heard they tend to throw rocks too. I have had the Nitto Terra's before and dont remember them being bad for this. Never had the Goodyears. Also want a quiet tire too so dont want a mud tire.
Any recommedations?
I had some Bridgestone Dueler A/T Revos that didnt seem to be quite as bad but that has been a few years ago. I got a set of Mastercraft A/T 2 on my 97 and it doesnt sling rocks too bad. I also had a set of the BFG Rugged Terrains on my 07 GMC and they slung rocks like crazy. Cant comment on any Good Years.
I have the Duratracs. I don't drive on gravel and can't comment on rock slinging but they are quiet for an aggressive AT tire. Great tire on/off road and snow!
The stock Bridgestones are horrible for rock throwing. I now have Nitto Terra Grapplers and they are much better. I drive a decent amount of gravel.
Any tire with the voids in the tread necessary to be a real AT tire is going to pick up rocks in gravel. Most street tires will too.
I agree with others above, every A/T tire I've had throw rocks and some more than others. Hell, even my Trail Grapplers on my last truck would chuck a few from time to time. It sounded like someone shot my truck with a slug when it did too because they only picked up larger ones.
Yep, the BFG's are bad about throwing rocks. However, as stated, that's the case for many aggressive AT's. A street tire will only grab little, tiny rocks....while a mud tire will only grab the big ones. My BFG's seem to grab everything in between, lol
So far I have been happy with Copper A/T3's. I have a little over 2k mi so far, fairly quiet ( comparable to stock Dueller's) , and rocks don't seem to be too bad. Can't compare to BFG A/T's as I haven't had a set in over 20k mi, and can't remember!
Chris
I agree with getting flaps. The ones for my 2011 2500HD look like they came with the truck with a 100% color match. The running boards or side steps also protect the sides of the truck from debris thrown up from the wheels. All AT tread and even highway tread tires can pick up small pieces of gravel and send them hurtling at high speed at your truck or at the windshields of the person unfortunate enough to be behind you.
I have always appreciated manufacturers like Volvo and Toyota that provide effective flaps on their vehicles straight from the factory. If I added wider tires I added wider mud flaps at the same time. I have yet to own a car or truck that has not had to have the windshield replaced thanks to rocks thrown up by trucks on the highway whose drives don't bother with flaps when they put on extra wide tires with super aggressive treads.
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
