orviskid Posted October 13, 2012 Posted October 13, 2012 can you remove the tpm's and just use regular valves?? brand new truck and mine don't even read the right pressure. i fill them and they say the same thing. i figure its not a warranty item and i'm not paying for new ones. i wasn't sure how it affected the DIC. thanks
Portdriver Posted October 13, 2012 Posted October 13, 2012 I'd say it is a warranty item. Brand new truck? Yeah, let GM pay for it.
orviskid Posted October 14, 2012 Author Posted October 14, 2012 i'll keep trying them until my first oil change, then i'll ask them. i'd rather not have them, it's just something that will cost me money down the road.i can check my own pressure. they add more crap to cars that will just add to the cost down the road.you save on oil changes because the oil lasts longer and now you have to buy new sensors when you get new tires.
RyanbabZ71 Posted October 14, 2012 Posted October 14, 2012 It's a government safety mandate Just like rear back cameras will be in the near future Ryan
Mikeb52r Posted October 15, 2012 Posted October 15, 2012 can you remove the tpm's and just use regular valves?? brand new truck and mine don't even read the right pressure. i fill them and they say the same thing. i figure its not a warranty item and i'm not paying for new ones. i wasn't sure how it affected the DIC. thanks Yes you can to the original questions, but as Ryan said, against the law. You would have to find a "good ol boy" to do it.
Gurrzt Posted November 13, 2012 Posted November 13, 2012 it will also store a code in your computer which maybe a problem come smog time if your state requires it.
SouthCo Posted November 13, 2012 Posted November 13, 2012 You can use regular valve stems but you will get the warning on the dash and I'm sure the DIC says something. My wife's 05 Yukon Denali doesn't have a warning light on the dash but it does say check tire pressure or something like that in the DIC. YOu can hit the button and it toggles to the Odometer and the check tire pressure message wont come back until you turn the truck off and then restart. I put OEM 20" wheels on her truck some years ago but they had the wrong TPMS sensors in them. I didn't see the need to buy and install the correct ones as I keep a check on our tires. And at least in MD, I have no problems with it like this when I took the truck through the emission station (every 2 years in MD).
SouthCo Posted November 13, 2012 Posted November 13, 2012 With all that being said, it should be a warranty item though and I'd have them fix it.
brantjs Posted November 15, 2012 Posted November 15, 2012 Get them fixed under warranty. Also FYI you don't need to replace them when you change tires. I have had the same set in my car for 140,000 miles and 4 sets of tires. They do have to be careful when changing the tires though. I just put new tires on my wife's van and the shop broke 2 of the sensors. The tire shop was forced to pay for the replacement since the sensors worked fine before getting there.
