biggest tire able to be installed
ookev21
08' silverado 1500 v8, reg cab with ext bed, 4x4.
I have been reading alot on the forums. I have seen alot of this same question I'm about to ask. lol
My tires currently on my truck are 265/70r17. Im wondering what the largest size tire I can purchase and install without any mods to my truck?
thank you guys
So, you've seen others ask this question across the internet but rather than reading those threads to get your answer, you're asking again? Then you added LOL?
He probably wasn't able to find a concise answer.
As far as I know, if you're willing to spend a tiny bit on a leveling kit, you can fit 285's perfect. Someone with more experience will have to chime in though.
i did a good bit of reading and as kstruckcountry mentioned. I wasn't able to find answers pertaining to my situation (my truck). Im not a mechanic and I'm not gonna go on a hunch, that some of the information is similar to my application. I really like to see hard numbers. just like in construction, never want to assume that this is what your customer wants. Maybe a costly assumption, you know?
Well, if you need hard numbers, you need a tape measure and a notepad. Go out and measure your current tires, your clearance and then workout how much room you have from there. Jack the front end up a couple of inches to level and measure again. This question has been asked hundreds of times, and answered, regarding 1/2-ton GMT900's...your truck.
If you're not wanting to touch the suspension, then 275/70/17 is about the limit. With a level kit, the 285/70/17 will look great.
ok Ill try an find that info out on measuring my tires and wheel wells with a tape. Ill ask you guys again if I need help on that. Thank you everyone.
Im In the North East Philadelphia.
Welcome to the forum Kevin. You may also be able to get some answers from online tire retailers as well. The good ones won't recommend a size that rubs, it's bad for business.
I really think you will be fine with the 285 70 17! But it depends on the truck..Ive seen stock 2500hd,s accept the 285,s with no issues at all!
and others that did rub and needed some triming..
Say worst case it rubs a tiny bit.. Turn the torsion keys up 1 bolt turn or so, It will give the clearance and not be enough to need an alignment.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
    • Thank you.   I am set on a 3.0 Duramax as my previous truck with a Ford Ecoboost had just as many, if not more, "common" issues.  Cam phasers, timing chain issues, 10-speed valve body and CDF drum, emissions issues, etc.  So I figured, why not get 2x the fuel mileage (these things got 27+mpg on every mixed city/highway test drive I put them through) and better towing capability with resale value to boot?   My minimum, shortest trip will be 50 miles 1-way and I regularly go out of state with a travel trailer.  I'm planning on using this for a marketing/event promotion business also, which would require regular towing of trailers for bands, DJs, sound and lighting gear, along with my personal camera gear for filming events.   Looked at other trucks in the $30k+ price range but the issues seem to be everywhere, plus too many with gaudy mods.  I'm literally sticking with RWD trucks because they tend to be actually used as trucks, vs. the 4x4 models I've seen with unsafe lifts, huge tires, and general mods that would affect reliability (I'm wondering if some of them were tuned, hence the aggressive throttle response and hard shifting).   So my goal is to find a stock, 3.0 with 1 or 2 owners, in good physical condition, and decently well maintained.  Can't seem to find that up here, everything in the $27-30k range has had multiple owners, smoke smell, issues, or body damage.  Or the ridiculously modified trucks with 80k miles for under $27k but lots of problems...
    • That’s pretty tough Grumpy. I reread the previous few posts. They all reference oil changes. Much like your last thread. In my humble opinion it keeps things interesting.
    • Engine Wear and ISO 4406   1.) Cold Starts. 2.) High Particle Count. 3.) Low operating temperature viscosity and high low temperature cranking viscosity. 4.) Depleted AW, Friction and Acid packages.  5.) High engine load.    https://me.caltexlubricants.com/en_me/home/learning/from-chevron/heavy-duty-diesel-vehicles-and-equipment/The-Importance-of-Clean-Engine-Oil-and-Its-Impact-on-Equipment-and-Business-Performance.html   High particle counts have five sources. 1.) They are manufactured within the engine. Both wear debris and amalgamation of degradation products and combustion driven soot (worse in GDI). 2.) They are ingested via intake air. Ever hear the best oil filter is a good air filter? 3.) They are entrained in the fuel. 4.) This one is insidious. They are introduced in 'fresh oil'. 5.) They are introduced during the oil change.   ISO 4406 is the test that measures and quantifies the combine effects of all of the above particle related issues. You can mitigate your way into multiples of engine life by being attentive to them all.    https://www.hyprofiltration.com/blog/is-new-oil-clean   (from the link above)    [Quote] What Is the Recommended ISO 4406 Cleanliness Code for New Oil?   A good upper limit for new oil cleanliness is 16/14/11 (ISO 4406). Typical new oil usually has ISO codes of 19/17/15 or worse, which is far too dirty for sensitive components. This can be a major cause of degradation and premature failure. [Close quote].     Source of graph: Machinery Lubrication (GM Study)
