I have a 2007 nbs 1500 5.3 and when i start it cold it has low oil pressure around 25 psi 80% of the time, normal start up it has 40 psi up and some times it drops to 0 and i shut it down. most of the time it stays at 25 psi and does not move even with reving up the motor a little. then after running it for about 10 mins all of a suddin bang the neddle jumps up to what i beleive it normal idle around 30psi and crusing around 40 and at 3000 rpm about 55psi the truck has 320 000 KM and i have just changed the oil pressure sending unit and checked the filter right below it and it was kleen. i think its crazy that i have lower oil psi when its cold then when its warm but it only does it in the morning first start up i drive it to work and it sits there all day and after 9 hours i start it up and its normal, thinking my next step is to drop the pan check the oil pick up and pressure relif valve, mabe even change the pump any ideas???
Thanks for posting the fix in case somebody else has an issue. Yeah, my oil psi at start up is slightly higher now that the colder temps are here.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
