I wouldnt go with anything higher than a 4.56, and many of the guys on here will tell you that they wouldnt either. I was going to go 4.10 because I was concerned about mileage too, but there are several people that said 4.56 gave them better performance and MPG than the 4.10s. Im gonna go with the 4.56 in mine because I dont like the idea of constantly running 2500 RPM in OD. That would be a happy medium between 4.88 and 4.10.
  • Replies 31
I'm guessing you're running the 4.88's currently? I know at about 70 mph with 3.73's my rpms run a little above 1500. Do you know what kind of rpm's it would run at the same speed with 4.10's?
Everything is retuned for tires and gears, yes.
Im debating on going 4:56.. I have 4:10,s now..but am going to run 35/36" tires
With a 5 spd allison I feel ill be ok, the cost is just alot on mine end with an 11.5" ring gear.
What was your original gear ratio?
When I said higher, I meant
No, I only have the factory 3.42 gears at the moment.
Check out this calculator to get an idea of gear ratios and their affect on RPM.
http://www.novak-ada...dge/gearing.htm
When I said higher gear, I mean a smaller number. For exampler, 3.42 is a higher ratio than a 4.10, and a 4.56 is a lower ratio.
Persoanlly, with the 5.3, Ide try to stay around 2200 to ballance power with economy.
I'm running 88s with 37s which is appropriate per the generic calculators around. I was running 35sbefore and the truck was a beast...still is but not quite as snappy. Anyway my highway mileage didn't improve much but in town I went up a solid 2 mpg upon regearing. Those charts calculate size...not weight. They don't take into account the added weight of the tires let alone the wheels. They darn sure don't factor towing into the equation. I recommend you look deeper into this issue and check around the other forums, where these topics and the requisite knowledge is more prevalent. I'd say I was recommended 4.88 over 4.56 by 10 to 1. The off road shop being one of them. I'm no expert on this topic but I'm happy with my decision. As far as rpms o, the difference at 70 mph between 56 and 88 is like 200 rpm, which is nothing.
QFT
I also have another question. I got the truck at the dealer now, and was gonna have them do the work since I'll provide the parts. If they regear the rear to lets say 4.11's and I leave the front at 3.73's for maybe 30 miles to get it home, would it be alright, or will I bind something up even though its in 2WD? If I can do that, I can get a front differential from a scrap yard with the stock 4.11/4.10 gears in it and just do a swap at my house.
Cause I know if I buy parts to regear and rebuild the front diff. and have them do it they will charge me what they charge me for the rear end plus another couple hours to pull the diff. and reinstall it after it is done. Would like to get this answered so I know what my options are for getting my truck home.
You should be fine in 2wd, but dont ever lock it in like that or your transfer case will become a trotline weight.
I didnt realise you were running 88s. Does your truck have the 4 or 6 speed?
My thoughts were that on stock tires, a 3.73 gear suites me fine for what I do. Adding the 35" tire into the equation, to acheivethe same RPM, I would put 4.10s in. But since the tires were also heavier, I figured the 56s would make upt for that without having the engine scream all the time, since most of my driving is 70-75. What kind of mileage did you see with the 35s?
I dont want a dragster, but I do want her to be able to move out of her own way. The 3.42s I have now dont really bother me except for the fact that it will downshift at the slightest incline. She holds 60 pretty good, but 70 is a chore. When towing I just run 3rd gear which gives me a mechanical equivalent of 4.88s, which tows really well, but runs more RPM than Im comfortable running all the time. Maybe Im too old school and too used to the old SBC.
So just talked to the shop foreman and he was saying that 4.10's may not fit the differential casing and that the inside diameter of the ring may not fit the posi unit. I don't really believe him, cause I'm sure there are plenty of guys on here with a 10 bolt rear main running aftermarket 4.10 gears.
And I'm sure Randy's ring and pinion would know if I had to change anything. I was thinkn of going Yukon gears cause of their warranty. Anyone have success with these brand of gears?
Umm yeah they'll fit fine, if anything you'll need new carriers. Go to a different shop!
Z71 i was getting 14 in town but I was running large 35s and 20 x 10s. And that was optimal driving. Oh it's a 4 spd
did you do the regear when you went with bigger tires or did you ever run stock gearing?
I can get a consistent 14.5, but Im wondering if it will go up or down with the 4.56 gears on the highway.
I ran the stock gears for years and got 11-12 mpg. But I'm rocking 10" of lift and a much heavier set of wheels/tires.
I was going to buy a Yukon posi unit for the rebuild anyways, so I'm sure their own ring will fit their own posi
I gotcha. Im just trying to guage which direction my mileage will go with the regear.
One last question (for now). Did you go straight to the 4.88s or did you ever run the 4.56?
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
