Chit chat
SarahsGMC
  • Replies 9.5k
Bought a chest freezer today
Why would you want to freeze your chest? I thought that you liked the heat there? What am I missing O'SEMA Lord? :jester:
Bought this because I don't have room in the house for Costco food
http://m.sears.com/kenmore-8.8-cu-ft-chest-freezer-black/p-04612909000P
Or you're a serial killer and you put bodies in it!
Sent from my SM-G930V using Tapatalk
^ only serial killers double post
Dumbass Tapatalk working at its finest lol
Reviews are trickling out and it's kinda comical how freaked out some are at the LeEcosystem apps. One reviewer echoed me. Throw on a Launcher at boot up and take advantage. of the specs. It has less bloat than a carrier branded phone, even excluding most manufacturer specific apps (like health apps). Tom's guide measured the display at being brighter than avg, and very accurate colors. More accurate than Pixel or iPhone 7. I'm still debating to get another for my wife , or Axon 7 or LG G5. Hate to have two if they bail out of the US market, but if they come through with updates might regret not buying another.
Battery life is fantasic, at 68% and my G4 would be at 40 by now if I was lucky
A good a day as any to do a much need reorganization and matching of holsters. Especially since I pulled them out of the closet over the weekend. So lazy :-(
Tip: Shoe organizers work great and they hang up in your closet if you want that type.
I feel like I'm missing one or two somewhere.
Mods here don't get fired, they go missing
Eh, we all know where to look first.
all this desert, good luck
Swamps are more interesting.
Coyotes, gators, as long as they get fed right?
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,271 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
