2 add-a-leafs ?
Ive used add a leafs in the past with good results, But im curious if i can use two on each
side vs just one, I figure it would give me the little extra height i wanted and then add
some strength and load capacity, And/or find a leaf pack off a similar truck and put a few of the leafs into my pack with the add a leaf spring,
What are your thoughts? Thanks
  • Replies 31
Yes, you can add all the leaves you want. Just remember to get some new u bolts. If you are looking for the strength without the height, check into some timbrens. I replaced my factory overload bumpers with timbrens and love it. They are much tougher. Still have a little suspension travel, but when you put the big trailer on it, it holds decent ride height, which helps keep the front end on the ground.
I was going to do the hellwig add a leafs also, but i look for the timbren things your talking about and didnt find
the right thing I dont think.. Cam you give me a link?
I wouldn't recommend adding two of the shorter, thicker, add-a-leaves.....it's going to ride like crap. Adding a few extra factory leaves to the pack, or using the longer, thin, add-a-leaves will give you a better ride. You could also get your springs re-arched for more lift...then add something like air bags for adding towing capacity.
What the heck are you hauling that requires that much spring on top of the factory 3500 springs?
If it were me, Ide do the factory leaf route. Just make sure you get the isolator pads to put between them, or they will squeek like the devil. I added a 2" AAL to my 1500 and didnt put anything in between the leaves, and it constantly squeeks offroad.
Whatever you do just remember that the springs are not the only thing that determines payload. Make sure you don't exceed your axle and tire load ratings.
I haul big loads of firewood,2b stone,etc.. I have it loaded with firewood were the springs were flat and starting
to bend the other way.. Why would it ride like crap adding another spring of two to the pack?
Im pretty sure the trucks good for 94 or 9600 lbs, And my tires are E,s @ 80psi and 3350 lbs per tire.
Ya just watch you loaded GVW. As I said before the timbrens help once you load it. Won't affect the ride when unloaded, but a leaf won't hurt. Some people just don't understand what its like to actually use a truck for a truck, not for a prettyboy pavement ride.
It increases the spring rate of the leaf pack, making it stiffer and harsher. It will ride ok if you are loaded down with 500lbs in the bed all the time, but unloaded it will feel like your riding on bricks. Bed bounce will be horrible.
Another Negitive comment...... :nonod::nonod:
How is it a negative comment? He asked for help, and I gave him a fact. AALs make the leafs stiffer, adding 2 will make it ride like $hit. If you are that upset, please leave.
    RyGuy43
    RyGuy43
  • Who's Online   4 Members, 1 Anonymous, 657 Guests (See full list)
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
