Just picked this up about a month ago. This is my new daily driver since the Subaru blew up.
8e21d700-0f51-40fb-97c7-52a99958cdd6_zps
How did you blow up a LGT?
The oil pump stopped working and in less than 2 miles from when my oil light came on and I limped it home it started knocking bad and smoking. I took it to a shop that only works in Subarus and they said the turbo may have been saved because I never went into boost but the engine was toast and needed a full rebuild.
They quoted me $4000 to fix but they were 16 weeks out from being able to work on it. They do one rebuild a week and had 15 ahead of me. I guess turbo Subarus have a bad habit of blowing after about 120k miles sometimes sooner. I spoke to another shop who could have rebuilt it right away by they quoted me $8000 and the dealership quoted $10000.
The original shop offered me $4000 for the car as is. So I took it. It was only worth about $8k even with the rebuilt engine so i said screw it and I sold it to them.
I really like my new car and I got a great deal on a much nicer, faster and lower mileage vehicle that should last me a while.
A couple new pics, fresh detail.
  • Like 5
I want one!!
I want one!!
You have good taste my man. Corners like it's on rails.
Thanks bud! I've always had a soft spot for Vettes.
Absolutely love the color!!
Sent from my iPhone 6+
Shiney, a Vette would be nice but I need more seats
Ryan
well, I'm building a truck, that is considered a other ride, right? its a 2004 F150 lariat with a raptor bed and front clip. bagged ford Raptor laying frame on 26's
  • Like 4
I really regret getting rid of this one. 97 LT with 4.3L, 2 wd, 5 speed, 4.10 gears. This is what it looked like when sold mid 2010.
100_0105_zpszivps4km.jpg100_0094_zps5618e9f0.jpg100_0095_zpsccb9b016.jpg100_0103_zps94536042.jpg100_0101_zps5467d6e0.jpg
  • Like 3
Wow that was a clean truck, to bad it was a 4.3… Nothing wrong with it, just would be so much cooler if it were a 5.7…
Not much weight there. It could spin tires in 2nd. It would get over 20 mpg.
Edited by Chevor
We drove to the Bloomington Gold Corvette Show in Indianapolis this weekend. About 1100 miles round trip, great weekend! Mine was one of 8,750 Vettes at the show. :drool:
Edited by Luster
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
