How-To: Painting Front Emblem GMT900.
The contrast of the gold emblem is great imo. I don't understand why there's a need to paint it.
Thankyou for bumping my topic with your opinion. Although there is no NEED to paint the emblem. Many people WANT to paint it to give the vehicle there own personal touch. That is the wonderful thing about owning your own vehicle and personalizing it .
BTW, I don't see the need of having the Michelin man in your avatar.... I guess its just something you wanted to do to personalize the forum to you liking....
Agree 100%!! Customizing my rig is something I'm interested in, and I want mine to be as unique as possible.
IMHO the gold Bowie looks awful against most colors. Color matching or having a different contrasting color is the way to go. Oh yeah, and F*#£ stock!! Especially when you pay $30K for something, make it your own!
As far as I know there wasn't a standard issue avatar that I changed from. :)
And you guys are pretty touchy, I didn't mean to hit a nerve.
No issues here, and not touchy at all. This site is full of big boys and girls who typically speak their mind and are A'Ok with differing opinions. I think the line about the avatar was likening it, in kind, to customizing a vehicle. You got your style, I've got mine.
agreed.
white1500, it appeared that your reply on this topic was to bash people that paint there bowties because you think there is no need to paint and the contrast is great... When making statements like that it only puts up a defense guard imo. Did not mean to get touchy, But I put this topic here to be informative to other members who have interest in it.
I painted my front bowtie insert white, and plasti dipped my back one black. Thanks for the write up, made doing the front easier. Even if not needed ;)
  • 2 years later...
Here's a simple mod anyone can do with a little time and little $.
First step is to remove the bowtie.
What i had to do since i have big hands was remove the plastic cover that is over the radiator. There is about 8 pins or so.. Pry the pin up and remove the clip.
Here's the piece i am speaking of..
Next take a small slotted screwdriver with stubby handle and there are 2 clips behind the bowtie. You have to put the screwdriver next to the clip and pull to opposite side of vehicle (driver to pass ans pass to driver)
Be sure to hold emblem with other hand so you do not drop it.
Here is what the clips look like front behind.
Next step is to pop the emblem apart. This is if you want to have 2 colors.. I chose to leave the stock black border on there and have white in the middle.
To pop apart I took a slotted screwdriver to either side and worked it in very slowly. Once the screwdrivers are 2" in or so, it will seem as it wont go any further because of the combination with glue and tape. Very gently start turning the screwdriver to slowly pry it apart. This may take a while.
Once you have popped them apart it will look like this.
Some people may sand the factory emblem for a better bond, I prefer a bonding primer meant for plastic. This way you keep that smooth finish.
The primer I used was made bu duplicolor , and is meant for plastic bonding.
Spray light and even, 2 coats..
Next it to spray your color of choice, mine being white to match my front end. I also did 2 coats of this.. Product used was duplicolor "perfect match".
The final application step is to spray on the clear coat. For this be sure to use only duplicolor perfect match clear... I used a different brand at first and it yellowed! I re-sprayed and topcoated with the "perfect match clear " and it turned out great. Be sure to spray a couple coats of clear to give it a gloss look and durability.
Allow topcoat to cure for a day or 2, before handling to glue back together.
Next step is to mend them back together. For this I chose hot glue for the reason if I wanted to re-separate later on and re-paint it would be easier to pull apart than a epoxy..
Here is the final outcome after gluing.
To re-install on truck, simply line up on grill and push back on. It snaps in.
Some final pics on the truck.
Any questions, feel free to ask.
I'm assuming it's around about the same for the rear as well, looks great
Not sure about the rear. I never got around to doing it yet. I did buy a american flag wrap / decal overlay for it tho that i may use on rear. undecided yet..
I pulled mine off and left it off, looks good but painting it had crossed my mind
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
