Here's another great job by Chase!
I always love these jobs. This is the wife, of the client I did the Cayman for. GREAT people, and they've seen what my hands can do. This is her daily driver, and I think they'll order up a polishing package in the summer, but for now it was just a wash, clay, sealant, interior job. I'm always very grateful for return clients like this, and furthering our relationship. I went to the client's house for this one, here's how things went down:
On to the pics baby! Arriving on the scene:
Lettin' the DWC & APC get right down to work:
Engine bay before:
Washed & Blow dry:
Always check this area during a wash. The lugnut brush is used for MANY other areas than just lugs:
All done washing:
Ready for a pool rinse, let the car help dry itself:
Hittin' those fender wells before moving forward, in case any overspray gets on the car, I have a few steps after, to remove it.
I don't dry the car beforehand, when I clay. Any water left on the car after rinsing (ALWAYS DO THIS IN THE SHADE OR GARAGE) acts as lubricant for when I clay, and then I use the Great White Drying Towel to absorb what's left behind. I took this pic, so you can see all the dirt and junk left behind, EVEN AFTER a wash, absorbed into the towel. This is after just the roof.
I always like to dress all areas with SVRT & In/Out Spray BEFORE I apply my LSP or do my IPA wipedown, because I'll remove any accidental messy areas, in the steps to come. Here's a 50/50 of the rear step pad, after 1 coat of SVRT:
Buttoned up after 3 coats absorbed:
Engine bay afters:
Tire & Undercarriage afters:
Wiper cowl & roof rack:
Since I didn't do any polishing, I moved right into the IPA wipedown. Again, you can see what I've picked up in the towel. This is after half the vehicle has been wiped down. Just another crucial decontamination step, before sealant is applied.
Moved on to scrubbing the interior:
Super clean creme leather baby:
Final exterior shots:
Thanks for reading!! Holler if you have any questions!! :)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
