Tranny over heating while towing
so I've been driving around all day today without the tow and haul mode on and the transmission has stayed below 175... Who knew!
I'm still going to get the upgrade cooler but it's great to know that this works too
You drove without it on? Normally while towing, this will increase the trans. temp due to the lower shift points and having to go in and out of OD
  • Replies 235
well either earlier in this thread or in another thread I heard that taking it out of that mode will keep the temperature down.... And it did!
I know it was designed for that to be on while towing but I just kept it in 3rd when needed and then put it into drive when I need it over drive seem to work well my temperature stay down all day
As long as it works and keeps that temp. down that's all that matters. Now put an aftermarket cooler on there and you'll be golden. It's weird how one thing works for someone, but not for another on these trucks
BIG ASS COOLER!!!!! That's what you need
Weird, I kno.. And today I drove around without the trailer today (I drive it hard) and Temp was up to 200! I don't know what to think.
Also, I already have a cooler but apparently it's not enough.
Just got the 70266 today! I'm excited to do install on Saturday just need to get few fittings and I'm good
Post your temperatures once you have a good feel for what it is. I want that same cooler because there is no rubber hose needed, hookup like stock.
Don't forget you will have to fab up a bracket or two. Might wanna do that ahead of time so you can paint it if you want
I spent all day looking for these fittings and I can't find them can't install itI wasted a whole day I'm pissed
I would just order them online to save time and frustration and then install it next wkd
cant go another week with my temps over 200deg. its 90deg outside now.
and I don't know what I need. every fitting I was told does not fit. its not 3/8 npt from the cooler line its like in between?
Yes, it will fit like a stock auxiliary cooler. If you get the reducers that chawkins6789 mentioned, and then hook up the quick disconnect fittings from the stock cooler onto those, and then it hooks up exactly like stock (just need to customize a few brackets to mount it). I wish I would have gone this route instead. Here's a link to someone who installed one on another forum:
http://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/new-tranny-cooler-install-b-m-70266-a-467897/
Hopefully I don't get in trouble for posting a link to another forum...
what fitting did he use for this? I cannot get one that fits from new cooler to the stock lines. Do I have to remove the fitting on the stock line and replace it?
You should probably take them off and wrap it in teflon tape to keep it sealed up in the future. There is a clip on the fitting that snaps out in order to pop the fitting off.
And on that thread I posted, he used 1/2" NPT to 3/8" NPT reducer (male to female). Not sure what you can't find one. Go to your local hardware store and go into the air compressor section. They should have a couple of those adapters
I still don't get it...I have that reducer but how do I connect it to the line? after I take off the fitting on the end of the line, how do I connect it to the reducer that I installed into the new cooler?
The connector on the line is a male. Your connector should be male into the cooler and female on the opposite end.
Is this going on a truck bigger than a 1500? I'm on mobile theme, so I can't see your signature
It's a 2500HD. Don't know if that matters, but the 3/8 female does not accept the male fitting. It's smaller. It's like between 3/8 & 1/4 npt
    mark2
    mark2
  • Who's Online   3 Members, 0 Anonymous, 523 Guests (See full list)
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
