I finally felt confident enough to clear my headlights after reading and watching the videos on GMFS. Sooo glad I finally did this. It's really too simple to pay someone to do it.
I also welded on a 5" stainless tip from Summit. I'm not sure the tip location is exactly where I wanted it, but I'm happy with it for now. I have some RC UCAs I need to throw on the truck too. Let me know what you think. As always, ALL opinions are welcome. :thumbs:
I ordered Stealthbulbs but they're a week out, so sprayed my amber bulbs with high temp
silver spray paint and so far so good.
They look just like Stealthbulbs in the truck
I may have lost a little light output, but not much
3" in 5" out stainless tip from Summit
Looks awesome! I would love to clear my lights, but I'm to chicken to try it lol! I like how you did the exhaust tip too. :thumbs:
Thanks man. The 5" tip actually deepened the tone a little.
And you should totally clear your lights. It's really easy. I used a dremel tool and it's really quite basic. Took me less time to cut and clear the lights than it did to remove the damn things. :banghead:
Soo much better!
Looks great man!
Sent from my SGH-I927 using Tapatalk 2
Let me know how you like the stealth bulbs. I've been debating swapping my amber ones but idk
Will do. I expect them here within a week.
Looks great!
I need to do something like this to mine, I like that tip.
What kind of muffler you running?
Thanks. I'm running a Flowmaster 50 series.
Looks good.
Where were your pictures taken? The background looks super familiar.
Soo much better!
It's amazing what a difference just an exhaust tip makes when it comes to sound. I need to read up more on clearing the headlights because it looks sweet with the stealth bulbs. Cleared lights will look sweet with my eventual HD front clip.
So many more mods I need to do to my truck.
Seat covers, new muffler, Line-X, gears, new grille, & clearing the headlights I need to do also.
Its a never finished job.
What are Stealth bulbs? I never heard of em & where did you get em at?
Man you've been busy, I can't get over how nice your truck looks with cleared lights. Amazing how such a simple mod can change the look so much, love the tip also. Did you do anything besides just make a clean cut where the muffler starts turning down?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
