It's amazing what a difference just an exhaust tip makes when it comes to sound. I need to read up more on clearing the headlights because it looks sweet with the stealth bulbs. Cleared lights will look sweet with my eventual HD front clip.
Oh yes they would. The all Colormatched HD front end would look killer. Check out these links. It's so easy to clear these headlights you'll wonder what took you so long.
http://www.gmfullsize.com/forum/showthread.php?t=112077
So many more mods I need to do to my truck.
Seat covers, new muffler, Line-X, gears, new grille, & clearing the headlights I need to do also.
Its a never finished job.
What are Stealth bulbs? I never heard of em & where did you get em at?
No sir, it never ends. Stealth bulbs are chrome bulbs that in my case shine amber. So when you have pretty clear heads, you don't have amber bulbs showing. It's much cheaper to paint them though.
Man you've been busy, I can't get over how nice your truck looks with cleared lights. Amazing how such a simple mod can change the look so much, love the tip also. Did you do anything besides just make a clean cut where the muffler starts turning down?
Thanks. Had preexisting 3" pipe dumped over the rear axle. Was originally dumped before the axle, but it was blowing on the diff and my gear guy didn't like that.
Calvary Baptist Church in Beaumont
I knew it looked familiar. Spent a lot of time traveling that road after my parents moved to Nome. Truck looks great. Ill keep an eye out for it next time Im in the Big B.
I call sorcery! No one can keep a black truck so fresh.
Sent from my SGH-I927 using Tapatalk 2
Flag me down of you happen to see me.
Looks good! Wish I had time to keep my rig looking that good.
Thanks
Haha.
I like the look of the cleared lights, but don't be surprised if you get ticketed because now your truck doesn't meet DOT specifications.
See I don't understand this because the bulbs still glow amber and the surface is reflective still. I checked with my local law enforcement before doing mine and they didn't care if I did it
And what will I be ticketed for? I've been a cop for 9 years.
Front turns in Texas have to glow amber or white or a color in between....that's it.
Federal standards require certain color reflectors in the lights. It's not something most officers will know enough about to ticket though.
Yes it would. I have seen a few at the dealer where I bought my truck, and they do look awesome. This is a members truck over on Custom GM. I was going to do mine just like his only everywhere his is white mine would be blue granite, but after seeing the whole front color matched idk.
I've never seen a requirement for anything other than rear red reflectors. Besides state law can't be less restrictive than federal law. If you find something please pass it on to me.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
