Blower motor(intermittent), ABS light on, parking brake light on
dpauli
My ABS light and parking brake light only come on when my blower is turned to 1,2,3,or 4 and the blower wont work(no air). But if my blower is turned to 0 both lights turn off. If i turn the blower to speed 5 the blower pumps at max like normal and both lights turn off. Brake fluid level is good and the A/C works ice cold(usual) only when blower works at level 5. Help please?
First off, wrong section, second, you need to change out your blower motor resistor and wire harness. I also believe you can take it in to the dealer and they will replace it or if you fix it all yourself then they will compensate you.
