Ya I noticed there's a huge difference between 7" and a 7"-9" lift. What's the total height gain with a 7" on 35's? Wouldn't that theoretically be about 10"? I'm no math genius but I think that's the actual gain in height.
I never put a tape measure on it, but that's gonna be pretty close.
You have to split the tire diameter, so in "theory" it would be 8.5".
I've got the 7" RCX in my truck. Running on a set of 32s right now tell my wheels n tires come in and honestly the ride is a bit bumpier then factory but I think a lot of that has to do with large rear block. Very happy with the ride quality of the kit, would definitely order another one, the only thing was I thought 7" would have been taller lol
I suspect you are right, but the right shocks would go a long way to smoothing it out. Now, the right shocks?? :rolleyes:
Has anyone experienced a vibration that started after having a 6" Fabtech lift installed? Mine is the 1/2 ton with the short box.
Just upgraded my RCX 5" to 7" with Fox Coilovers and rear shocks with Metal Moto 20x12 -44 with 35x12.50x20 Nitto Trail Grapplers. I am rubbing on the back wall of the front fender well. Hopefully I can find a way to keep it from rubbing. Any advice?
Got any more pics? Truck looks sweet
Fabtech 4" lift, 295/60/20 trail grapplers on 20" BMF REPR's
Great looking truck! Do you rub at all?
Do you have any pics with the 5" installed? How did you like it?
I have a vibration sometimes. It could be the tires though. I will have them rebalanced when I get my new wheels in next week to check.
Yes, please..more pictures. And take a pic of where it rubs on the backside. Does it rub turning in, out, or both?
How big of lift do I need to fit 35"s. With +18 offset. Looking to go smallest lift without cutting.
What rims are they? 20x9? x10? Or another size other than 20s? Also what is the backspacing
I know Zone off-road (4.5") and BDS (4") allow you to run a 35x12.5x20 tire if you run a 20x9 w/ 5.75" backspacing
20x9 not sure on backspace. Thanks for the info.
