Finally had time to post some pics. 6" BDS lift, 35x12.5 on stock AT wheels.d96047781156ed4ad07ac2166bbfd09b.jpg32e31da8154af1786b6721fe3629de8d.jpg
you sir...have the PERFECT lift...
thanks....my 2" level on 33s was not enough but as soon as my tires show a bit of ware im doing this,,,,'
even wrote it down !! lol
sorry for the double post but.
what is the biggest lift i can go with for my 33x12.5x20s on stock wheels and not make it look like skinny legs?
I'm running 33x12.50s on my sierra with stockers and a 2.5 in level. I think it looks perfect
Sent from my XT1254 using Tapatalk
Edited by Olgrey93
Thats what i have and im not satisfied.... I need more lift.... Bur also wanr performance ughhh lift/tires/regear or supercharger....
Same here as far as more lift...that's why whenever I get the coin saved up I'm going with a 7-9" lift to skip the mid level lift
These 6 inch with stockers on 35s are just perfect...... I fell in love lol
All these trucks look awesome!!!! I just picked up a 2014 GMC Sierra and opted for a mild lift - 4" SST ReadyLift, new tires and wheels.
4inchreadyliftsst29555r20onmotometals
Anyone have the 6in bds lift kit with fox coil overs? How's that ride? I have the standard 6in kit bds offers with fox shocks in the rear and I feel as if the ride is better than stock. I just want to know if it's worth the money upgrading to the fox coil overs?
Just out of curiosity, what size/offset wheels, and size tires did you go with on your 4" lift?
Thanks
Josh
Hi Josh,
I will find out today what my backspacing and offset is at, My tire size is 295/55R20
Thanks,
Pete
Hi Josh,
Thanks,
Pete
Thanks, I appreciate it. I like the stance of your truck. I just ordered my lift components last week. I went with a 4" BDS, 18x9 Fuel Cleaver wheels with a -12 offset and 4.75 backspacing, and 305/65/18 BFG KO2's. I did a lot of research before deciding on all of this. I also contacted BDS directly to see if I'd have any rubbing issues.
Josh
Josh, your decisions sound great! Can't wait to see some pics!!!
My backspacing is 5.0 and 0 Offset
The coilovers are well worth it. You don't have to go with Fox either. You can get Icon and King as well.
Sent from my SM-G900P using Tapatalk
Excellent, thanks for checking. Do you have any rubbing issues? Specifically at full lock in reverse? Does it look like you still have room to run a bigger tire in that position?
Thanks
Josh
    DM22
    DM22
  • Who's Online   4 Members, 0 Anonymous, 2,202 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
