Have any of you guys with zone lift or similar done any other suspension mods to your trucks like after market shocks for the front and rear? I'd like some options for rear shocks. what's available for us zone 6.5 folks? What about aftermarket control arms? Or sway bars ? Any issues with fitment with zone lift?
You can get custom length fox coilovers with resivors directly from fox for around 1600-1800 I believe just for fronts. You can also get the matching length rear shocks for a few hundred bucks.
You can also contact king shocks distributors and they can order you custom length ones.
Other than that you can just get oem spec coilovers and keep that extension above the springs but I think if you go coils might as well do it right
another pic.. it only is letting me upload one at a time....ill stop with 2 pics
Saw this at the dealership today....[emoji1360]5ded50319a3a687ceefe01a0bd02df75.jpg
Can anyone tell me if there is anything I would need to know about adding a 1.25" body lift to my 14 sierra that already has a 6" rough country lift? I was gonna keep the body lift rough country also. I don't believe there to be any issues but wanted to be sure before purchasing. Thanks in advance
Sent from my VS995 using Tapatalk
should be fine
I'll check in a bit and let you know. It should fit fine. When i go to my parents place the truck fits fine height wise and its 7' i think
I have the 7 inch McGaughy and my antenna clears my garage by 1 inch with my 35" tires.
Edited by sealteem1
I know theres been threads made but ill just ask here....Does anyone have issues with their rear leaf springs making super annoying noise when reversing or going forwards between 0-5mph???
I am pretty sure it is the leaf springs but it is really loud
I went with Bilstein 5100 adjustable front and rears. The rear Part Number: BSN-33-185569 to avoid using a rear adapter extender. This allow me to go over 6.5.
In addition add 1.75 rear bora adapters for evening out the rims. My rims are 20x9 with zero off set, on 35x12.50x20 Toyo MT's. Made a trim to the lower left trim, due to wheel touching the plastic, but nothing else needed trimming. I left the sway bar alone, but due plan to change the UCA, once it is time to replace them. Planning to go with Baja's UCA. I put the lift on myself, which took a day and a half. I didn't have a lift, so jack and stands took awhile. You will notice a difference in the speedo, so I picked up a Diablo Trinity, which corrected it and also help with MPG, in addition made a improvement with addition correction. I am going to get the add leaf kit, to level up the back.
Edited by Aboogie808
In addition add 1.75 rear bora adapters for evening out the rims. My rims are 20x9 with zero off set, on 35x12.50x20 Toyo MT's. Made a trim to the lower left trim, due to wheel touching the plastic, but nothing else needed trimming. I left the sway bar alone, but due plan to change the UCA, once it is time to replace them. Planning to go with Baja's UCA. I put the lift on myself, which took a day and a half. I didn't have a lift, so jack and stands took awhile. You will notice a difference in the speedo, so I picked up a Diablo Trinity, which corrected it and also help with MPG. I am going to get the add leaf kit, to level up the back.
Truck is looking good man, it's good to hear we have rear options (Fox and Bilsteins), the front well, pretty much anything that fits stock will work due to the spacer from Zone to achieve the lift. I'm still on the stock tune, been on it for about 2,000 miles and speedo is off by about 5mph around 65-70, i do plan to correct that by either getting the hypertech or diablo and use a canned tune, truck has always run on 91 so i will try a 91 tune. other than that, i am happy with it. i was told 1.5 bora spacers would align the rear wheels to the front, good to know it's 1.75, did you have to trim the stock studs on the rear?
Thanks and glad to hear things are coming along. 1.75 there are no trims to the studs, so you are good to go. I was running the 91 setup, but go back in forth. Just remember to switch the mod, should you use the different gas. Yes, the spacer helps with the shock options. If you decide to want and remove the spacer, Kings and Fox shocks lets you get a true setup.
1.5" actually evens it (cv spacer is 1.5"), but a lot of guys opt for 1.75" wheel spacers due to not wanting to trim the studs. With the 1.5" spacers you need to trim the studs
anyone in Connecticut have any shop recommendations for a lift. not sure high yet but i def got bit by the bug. the RC level isn't enough anymore
Valley Truck and Off Road in Elliington, CT
Sweet pic!
Can't recall if I posted a pic since I added the 1.5" Zone body lift so if I didn't here is one. And if I did here's is another! lol :D
BDS 6" w/ Fox
Zone 1.5" Body lift
DPR Stealth 20x10 (-12 offset)
Toyo RT 35x12.5
0642695D-D817-4F7F-B65B-13FC70F5FCDA_zps
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 2,189 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
