Is it your wheels hitting the front fender? If so check out the NorCal Mod. If you don't want to do the Mod just don't turn your wheels all the way. I have 2017 Silverado with a 6" Fabtech Lift, Fuel Assault 20x10 -18 offset, 35" Toyo Open Country R/T......minimal rubbing only when backing up and turning sharp.
no rubbing nor did i have to do any trimming i have not heard of the nor cal mod ill have to do some research my rims are +18 so i got away without cutting.
Is the clunking occurring when you hit a bump or when you turn? Just curious.
yes to both:( once i get up to speed above 15 its fine even when turning its backing up or turning at like 5mph that it clunks and its quite loud
Mine rubs right on the back of the front fender. I bet yours is rubbing also. I would check under the fender well and see if you can find any marks. Also crank you wheel all the way left or right to see if it touches. It may not touch but if it is close it will probably rub while in motion.
That sucks guys. Hopefully its nothing major.
Hurry up and figure this out before I add my lift and tires. Haha
there are A LOT of discussions on this topic but yet to find one person to specifically point out what the problem is its not like a hey if you are having that clunking/popping noise yo need to do this to fix it. it usually ends in has anyone figured out a way to fix this lol
I'm assumingit started after you added the lift.
Nice to know. Never lifted a truck before so this is New territory for me. Always had lowered trucks. Never had any issues if done correctly. A lot less components too.
Is anybody here a facking Procomp genius or what? I can't, nor can the procomp customer support find the correct part number for the 6" lift for my truck... All I want is their best kit, front coilover, best rear shocks for my 2016 sierra 1500 cast control arms build date of 03/16....... heeeellllllllllllpp
Got a new to me '14 High Country.
Thinking I'm going to go with the 4" BDS and the rear leaf springs
Probably pass on the coil-overs due to the cost.
Anybody willing to provide an invoice showing less than MSRP? (on 4" or 6" BDS),
I dropped by my local authorized dealer and they quoted me the same price as what's
on the website, obviously I'm looking to save a few bucks...greatly appreciated.
Btw looking to use the local dealer here in Colo. Springs (Predator 4x4), however if someone
has had success with a shop in Denver please fire that out there might be worth the drive.
Edited by oodmoff
Well got all the parts ordered yesterday just waiting for shop to call so I can drop truck off, got 6 inch bds with 35x12.50r18 toyo rt on fuel assault 18x9
I've ordered my lift and rear leaf springs through the dealer and the price is the same pretty much through them and from the website. Only real difference is you save on the shipping by gettting free shipping sent to the shop
b5e51bacd616fe2be28adeb43408fe84.jpggot my fox coilovers installed the other. Drove from California to Utah. The truck drove awesome
What lift you got?
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.       Here is the Trail Boss interior.  Memory seats and Super Cruise are present.  All things the LT Trail Boss it replaces, and the RST it was based on didn't get on the current gen.  You had to go to LTZ or ZR2 for memory seats, and High Country for Super Cruise.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
