Has anyone personally installed bds leaf springs? If so can you guys pm I got some questions
ive done superlift leaf springs, but not BDS
i don't think its even possible to have two blocks stacked ontop of each other.
If you wanna get rid of the front spacer you can buy the front fox coilovers for about $1700 which will eliminate the oem shocks/springs and spacer
Nah bro, my truck is 2WD and never goes offroad, definitely not spending that much money on coilovers. I do however plan on getting new control arms and the bds front spacers in a couple of months :) Should give me enough suspension travel over what I have now.
Edited by arkenzo
Great looking truck!
thank you!
possible yes, safe no
why not just get the 6.5" Zone with the 6" BDS struts which are about $300 for the pair.
Is there a part number for the BDS struts? I looked and couldnt find struts, i found shocks, but not struts that would work with the stock springs
call BDS, they'll hook you up
look at the parts list , it's right there (not doing the work for ya)
Well considering there is no Parts List on their website, kinda hard to find something that doesn't exist.
They have links for Lift Kits, Shocks, Steering Stabilizers and accessories and in neither of those, are there any struts listed..
But appreciate the help..
https://bds-suspension.com/productFlyer/BDS_NPR-718.pdf
Look at the pdf. Part numbers are in there
Yup, 98164 for 6"
IMG_9695 by Chris Minshall, on Flickr
Dude, I love bronze wheels with tungsten metallic silverados (mine is tungsten metallic), would have gotten some bronze 20's but the wife did not approve.
Oh well, they look nice on yours.
35605312043_d5e572dd9f_k.jpgIMG_9695 by Chris Minshall, on Flickr
Dang - that looks great! I can't tell for certain - are those 35x12.5 Toyo MT on 18 inch or 20 inch wheels? I'm guessing 18. Either way, looks top notch!
Edited by pcruis1
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 885 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
