Whats up, just wanted to leave my footprint. Heres my 16" Silverado 1500. it has a 4 inch BDS lift, 275/65R20 Mickey Thompson ATZ P3 tires, wheels are plastic dipped until i find the perfect wheel combo. I have a Borla Exhaust S-type, Airaid Jr MIT, and a Diablo Custom Tune from Lew. I also have some Amp Research Power steps. Heres a picture of her all washed up and waxed with Adams Polishes.
Looks good did the same lift about a week ago yet to pick out a tire on stock wheels myself. Was thinking 285/65/20, do you have the add a leaf in the back or a 5" blocks? Edited by Steeks
Show us some pictures! I love the way the stock wheels looks plastic dipped black. It looks very good for now. I'm just really being picky about the wheels for my truck, I haven't found the right one that gets my attention. I have the 4" block, I don't think it should have the 5" block. I checked my invoice and it says 4" but who knows. The only thing is that I do notice that it still has a small rake to it. I brought it up to the shop "off road Warwhouse" in temecula but they said it was fine. I will be sending an email and dimensions to BDS.
Edited by 16chevy1500
if you don't want rake get smaller blocks, or put a spacer in the front. If you want attention grabbing wheels get billets
I will soon just haven't had the time been busy with work and been pretty shitty outside. Also how does a guy post pics here?
Tapatalk on mobile is just about the easiest way to post pics.
And who cares if its dirty..... It's a truck.
Sent from my SM-G935V using Tapatalk
I have this kit. I have 275/65r20 which is basically 34 inçh. I am thinking i can get 35s on easily.
This kit requires alot of cutting. Cannot be reversed unless uou are good with a welder.
But it doesnt change yourstock stance which is why i did it.
The knuckle or bracket requires a lot of cutting? I'm trying to avoid this. Thanks
I have the bracket kit. It required a lot of cutting. I am sure there is cutting in the knuckle kit as well. Just about every kit manufacturer has install instructions on their website. Take a look I personally was looking for the end result I got so it was the only choice for me. I didn't want a knuckle kit. I did not wanto widen the stance.
I gotcha. I didn't realize that the knuckle kit widen the stock stance. This will be my first lift.
Just got the zone 6.5 installed. love the ride but I went with the standard hydro shocks with the kit. Anyone know if the upgraded Fox shocks 2.0 are worth the upgrade or are they gonna be more stiff?
As far as ride quality now it feels like stock up front, a little more bounce to the back on the freeway but nothing too bad.
the fox's may help a little but the back is always going to stiffen up once lifted
Man I went from a leveled truck to the 6.5 zone and fox shocks and I swear my truck rides better than it did before. Even my wife commented on how smooth it it now...
lol damn thats what i didnt want to hear hahah. Well I kept the stock 20s on it so I will be changing those out soon so I guess Ill have to put the fox shocks on as well lol.
What kind of wheels you running rivertrail?
Edited by Bpun2016
Yeah I read tons of posts and people kept saying they road better - now I believe them. I always thought it was bs.
I'm running my stock all terrain 20" wheels for now. On 35 12.50 ridge grapplers.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
