Finally got the zone 6.5 and 35s installed. couldn't be happier with the results. I havent changed the speedo yet (hypertech arriving on saturday) but according to google maps my normal drive to work is 29.9 miles but the truck tracked 27.8 miles. Anyone have an idea on speed difference at 65 mph?
I remember from my old lifted truck on 37s the truck was reading 3mph slower at 65mph.
question on these Rough Country 5in bracket lift and Knuckle lift.
can i get the bracket lift and add knuckles for more lift down the road?
also which kit 4.5 to 7in is the easiest to reverse (minimal cutting)?
Edited by celflex
Rough Country responded with
"That 5" bracket kit will allow for 33" tires.
No you can not add a knuckle kit to it later for more lift without going to the knuckle kit suspension.
We do not have any active promo codes or sales at the moment."
Hey guys, I'm here as a noob... I've read up and down this thread and have gotten tons of info. I'm stuck between two kits. (Zone 6.5" lift or the RC 6" Lift)
I noticed with the Zone kit I cant re-use my factory 18" wheels and was wondering if there was a way around that besides getting new wheels. I have 33" BFG K02's (275/70r18) on them. If that helps with the issue...
Then it leaves me with the RC 6" lift kit that allows me to re-use the factory wheels. I'm curious as to how this lift will affect the ride. If I decide to go with this kit should I get the Premium N2.0 or the Performance 2.2 shocks? ( I do take my truck on trails just about every other weekend but nothing extreme)
Which do you all recommend?
Thanks in advance! Sorry for so many questions. This is my first truck. 2016 Silverado CC Z71 (oem ranchos)
Edited by Gseppes16z71
You may not be able to reuse the stock wheels. I have the zone 4.5" and the "nun" on the uca rubbed on the inside of the tire with stock 20s. However I can attest to the quality of zone twice over
I appreciate your response. Thanks!
If I decided to get an aftermarket wheel what offset would I need If I went with 18" wheel?(if I went with the zone lift) Trying to reuse my bfg ko2 since they only have 2k on them. I'll go bigger later on.
the issue for me was the massive amount of positive backspace and the little nub on the stamped steel UCA
"That 5" bracket kit will allow for 33" tires. [/size]
No you can not add a knuckle kit to it later for more lift without going to the knuckle kit suspension. [/size]
We do not have any active promo codes or sales at the moment."[/size]
I have this kit. I have 275/65r20 which is basically 34 inçh. I am thinking i can get 35s on easily.
This kit requires alot of cutting. Cannot be reversed unless uou are good with a welder.
But it doesnt change yourstock stance which is why i did it.
I don't mind cutting something that can be put back in and welded.
I just want the option to go back to stock if needed be.
That shot down my 4.5 or 5in lift idea.
Going to shoot for 7-9 now.
Something that's true lift, keeps track width the same and can use factory 20s
Edited by celflex
I've read a bunch of these posts and talked to a bunch of shops. Monday I'm getting the zone 6.5" lift and keeping my stock 20" all terrain wheels. Everything I've read says it will work. They have said that one of the smaller wheels won't work. I was thinking it was the 18" wheels but not sure.
Everything I read said it would too, my ucas (stamped steel) rubbed the inside of the tire 305/55 with stock 20s. Zone was at a loss. I think it depends on the type of ucas
2014_gmc_1500_black_widow_by_southern_coI cant seem to post pics from my computer unless its to my profile, but this is my current set up just want to get 37's under it.
I'd leave the tires you have on there. 37s will kill you gas mileage
Funny cause they show a denali with the bracket lift with 295 60 20 on their YouTube channel. Last i checked those weren't 33s.
The 4.75 is just the 3.5" lift with an added body lify so just be aware of your labor cost when installing both a suspension AND a body lift.
Sent from my SM-G935V using Tapatalk
after skimming 200 pages, i'm thinking cognito seems to be the best route.
anyone have any reviews on any of these parts? pros cons price etc?
14 sierra all terrain with stock 20s on 305/55r20 4x4
7" Front Kit 4wd - 2014-Up
Part #FSLK100727
Factory Cast Steel UCA/LCA (FSLK100727)
$2,180.00 Boxed Uni-Ball Upper Control Arm Kit
Part #UCAK100048
2007-UP Factory Steel UCA/LCA - (UCAK100048
$799.00 Fox Coil Over Front Shocks
Part #FOX-FSK-1007DSC-4WD
7" Lift Kit - FOX-FSK-1007DSC-4WD
$1,894.95 CMS Fox Factory Reservoir Rear Shock
Part #FOX-FSCAD-7R-1
2 x FOX-FSCAD-7R-1 - CMS Fox Factory Reservoir 5-7" Rear Shock
$259.95 Deaver Leafs
Part #LSDEAVER-G26
2 x LSDEAVER-G26 - 6" Deaver Leafs
$399.00
Subtotal $6,191.85 Grand Total $6,191.85
  • Proceed to Checkout
Continue Shopping
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
