Actually the only difference between Zone and BDS IS the warranty. My shop down here in California showed me both lifts and they are identical the only difference is the block size and the warranty. To be more correct, BDS was an already established company with a parent company called Zone. What separated them is the warranty but both are highly regarded of being equal quality. Fox only recently bought BDS in 2014.
More information on them here:
http://chuxtrux.com/n-10544-bds-suspension-vs-zone-off-road-lift-kits.html
exactly!
What'd that run ya?
I have a guy here in California that did it all for me for $1670 everything included out the door :)
Can anyone confirm if my driveshaft is supposed to be at an angle like this after the 4.5" zone suspension lift?
of course, the truck is higher above the axle causing a steeper angle
Will that cause any damage or is it putting any undue wear?
nope
Perfect thank you
They are not the same. BDS kits use new struts to achieve the front lift and Zone kits use a spacer that sits on top of the stock strut. Which is why the zone kits cost less. All other parts are the same though.
exactly!
you can get the struts BDS uses through Zone or the fox's through Zone also.
However BDS uses arched cross members and kicker braces which Zone does not. Essentially they are the same
Thanks for the info on the zone/bds. I also have a question. I have a 2wd but would like to put on 35s on a 4.5 zone. Their website says 33s for a 2wd and 35s for a 4wd on a 4.5. Wondering the difference as to why the clearance is different and has anyone done a 4.5 zone on a 2wd and put 35s on?
4wd from the factory sits either 1" or 1.5" taller than 2wd.
Sent from my SM-G930V using Tapatalk
how much rake does your truck have, do you have the fender measurements, im about to do the zone 4.5 and hope mine looks like yours when done.
    • How did all that extra get added? AI bot!
    • This is interesting. My quote tagged here is different from my original quote. After I’m driving them longer. That isn’t me. I don’t talk that way. I definitely wouldn’t express myself that way. Interesting.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
