Truck looks badass - what wheels and tires?
heres mine
9"
Just did the zone 4.5" lift on my 2015 1500. Switched out my 33s with 35s and they work I haven't trimmed anything yet but it will need little trimming on the inner fender lining. Running 20x9 +1 fuels
FYI for people thinking of zone lifts. Rides better than stock
Edited by Avinad
  • Like 4
Here's my 2015, 6" Pro Comp lift, 35x12.50-20 Toyo Open Country MT, 20" Helo wheels. Just got the truck 2 weeks ago and absolutely love the way it rides compared to my '13 F150.
Katzkins interior:
Edited by UFLBret
Looks good! And it looks way taller than my 6" BDS lift. I wonder why
Katzkins interior:
any pics?
Thanks man! I dunno, I parked it next to my buddy's '07 and he has a 6" BDS kit on it and we were almost dead level. He has same exact size Toyo's as me too.
Thank you I appreciate it. I'm super happy with the 4" although every now and again I think about adjusting it to 6" and after a solid minute say,"nah" lol. And I agree with you on the tires. I had toyo at2 extremes when I had my level but wanted something a bit more aggressive for the lift and stepped up to the rt's. I do have a pic of the side and I can always snap morec003814be668ded5421aaedb662a22aa.jpg
Even tho the fronts stick out about an inch it doesn't bother me and I don't notice it anymore. Of course more aggressive offsets will exaggerate things a bit.
have you had a chance to get measurements? Front,back, and roof
- 4 inch BDS rear block kit with fox shocks
- 20x9 Fuel Mavericks wrapped with 285/65r20 BFG KO2's
Sent from my VS980 4G using Tapatalk
love the look and stance. Do you happen to have the measurements front wheel well, back wheel well ,and the roof? Pretty much stuck on this lift and wheel combo. Edited by Steeks
Got mine back yesterday.
Zone 4.5" Lift
Method Racing "Standards", 20x9, +18mm offset
BFG AT KO2 285/65R20
Really haven't had any rubbing yet at all. I *thought* there was a little when backing out of a spot yesterday at full lock but it may have just been the road. No signs of it anywhere.
Hows the lift holding up? any Complaints?
2015 GMC 1500 6.2 8spd
8" McGaughy
35" Toyo M/T
20x12 Fuel Mavericks
8" McGaughy
35" Toyo M/T
Truck looks beautiful - love the color matched tow mirrors - this is like the setup I'd like to do - how noisy are the M/Ts? Trying to decide between those which have a great look and the little more conservative R/T
Yeah digging the look as well. Question, what did u use to black out the pillars?
I had a tint shop tint the front windows, ting the side markers on the two mirrors, and vinyl wrap the B pillars in black and the tow mirrors in white.
Love the Toyo M/T's. Had them on a lifted Titan before and was getting 40K miles out of them. Road noise is minimal given the aggressive tread. Plus these trucks are so quiet inside.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
