I'm in the same boat as you... just traded my 2010 FX4 f150 and this silverado 1500 feels so long and no truck like.
I am considering a 4" lift, but don't want to be unhappy if i feel 6" would have been ideal.
Truck is my daily driver (80-100miles a day 70% highway).
Correct me if I'm wrong, but seems "quality" is....
***** BDS and Pro-Comp
*** Rough Country and Zone
** Ready Lift
I think it was BDS that I seen had the $2K 4"lift. Rough Country is $679 for the one I would be getting, seen it last night. I also was curious about 4" vs 6" but I think 4" is plenty for me. The RC kit is actually a 4.75" lift
Going to research more today....
my biggest concern is really impacting the highway MPG badly, I understand there will be a drop, but if 4" and 6" make a difference, need to consider. Definitely sticking with 33" max
Edited by nhbackcountry155
The lift really doesn't cause a drop in mpg. The biggest drop comes from larger/heavier tires. A way to combat this is to regear. But if you're like me and have the 6.2L then re-gearing is not an option currently.
Sent from my SM-G930V using Tapatalk
Just got my truck back yesterday. 4.5" Zone Suspension Lift with Nitro Shocks part # C27N
  • Like 3
Looks great....I need to get outside and install mine.
You won't regret it. It rides way better.
Are those the stock size tires in the pic?
Ya those are 275/55r20 stock Goodyears. They don't look very awkward but I do think I'm going to get new tires soon.
They don't at all. I'm glad because I'm still undecided on which tire and size I will put on my truck. That is one of the reasons I haven't installed the lift yet.
I felt the same way about it and thought I'd have to save up to do the tires with the lift but I figured I'd just go for it and if it looked weird I'd spend the extra money. Turned out pretty good I think. I'll get it washed tomorrow and post a good pic.
** Ready Lift
BDS is Zone, Zone is BDS
Right. They are both owned by Fox Racing: BDS is just considered a more premium brand due to finish and offer a ridiculous warranty. The shop o got mine installed at said one of his customers rolled the truck off the road and BDS sent a new kit for the new truck...! Wow!
This article provides more details on this.
http://chuxtrux.com/n-10544-bds-suspension-vs-zone-off-road-lift-kits.html
Actually the only difference between Zone and BDS IS the warranty. My shop down here in California showed me both lifts and they are identical the only difference is the block size and the warranty. To be more correct, BDS was an already established company and was a parent company to Zone. What separated them is the warranty but both are highly regarded of being equal quality. Fox only recently bought BDS in 2014.
More information on them here:
Edited by jnach
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
