Cooper Tires now Indian Owned
  • Replies 44
CRAP! With all the American based companies selling out, its no wonder our country is in the state it is!
At least it isn't china. I hate seeing them buy up American interests.
Lost interest in those guys when they sold their commercial tires off to be made in China. Seems like once that starts, leaves you to wonder what is left or changed that they are not telling you.
Pretty sure General is still American owned/made. Whatever, seems like tires are becoming like electronics, doing the whole American made is just unrealistic. I'll buy whatever I think is best.
I just emailed Customer Relations at Cooper Tires out of frustration about this. It might not be appropriate, but it's early, I'm tired and I don't care. I'll let you know their response to this....if I get any at all.
This is what I asked...
I've been buying Cooper tires for my truck because it's a great tire and I'm tired of supporting other countries over my own. I recently heard that Cooper Tires has been bought up by India's Apollo Tyres. So my question to you is this....how long do we realistically have before the tires currently in stock at retailers gets replaced by lesser quality product?
Crap. :sigh:
Who still makes American tires? :flag:
BF Goodrich & Michelin. http://www.michelinman.com/about-us/who-we-are.page
I realize Michelin HQ is not US based, but the tires are made here.
After killing off a set of factory Generals on a 2007 Chevrolet Dually, I bought Michelin LTX's & that truck was used in a commercial environment & loaded heavy most of the time. Sold it at just over the 160,000 mile mark & they were close to needing to be changed. But still 113,000+ miles vs 47,000, sold me. Another aspect was having two flats with the Generals & never once with the LTX's.
Bought a set of Goodyear 399 steer tires for my Peterbilt semi & paid through the nose for them. But was buying from the last American tire company, so doing the right thing? They were shot at around 60,000 & pure junk. Have since replaced with Michelin XZA3's. Steer tires for semi's that are not Chinese are going to run over $1,000 for two, so one does not make these decisions w/o thought.
That said, when the factory Goodyears on the Sierra die off, they will be replaced with a Michelin LTX variant. They are tough to beat long term & check the link for the people they employ & where.
Yes Sir tractor trailer tires are ridiculously priced. Seemed like dad had to sell a kidney every time his needed tires!
Well if you're going by made in America there are tons of choices. But American made and owned is slim pickings.
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 885 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
