Need suggestions shocks 2008 z71
Need shocks all the way around 2008 z71 4x4 crew cab stock height 5.3.
Not looking for a harsh ride but not too soft either.
Thanks in advance!
If you go with bilstiens you can level it.
1 - Bilstien
2 - KYB
I purchased the heavy duty Bilstiens, and replacement springs (HD rear) for my 04 Tahoe, firmed up the ride tremendously, the rear was raised 1/8 of an inch.
Yes they are stiffer. I think it also depends on which level you set the spring clip at, the higher you lift it in the front the stiffer they probably are.
They get a little softer after they break in a bit. It's not a harsh ride and really does improve handling.
Much better than factory in my opinion. :thumbs:
The 5100s will give you a stiffer ride. I would suggest Bilstein HDs or the Monroe Reflex.
He is correct. I had the bilstein 5100 on my last Sierra and it made it a little stiffer which alot of guys like. But with this truck I wanted the stock like ride for road trips and for smooth everyday driving. So that is why I got the Monroe Reflex shocks. They ride really good, almost better than the stock ones.
Wondering did you replace to whole strut or just in inner shock for the front?
I just replaced the rear shocks so far. With how much the ride change with the just the rear the front will make it ride much better.
  • 1 month later...
Was pricing Bilstein/KYB/Monroe options out and went with the Monroe sale at PepBoys. 20% off and a get 1 shock free rebate with the Monroe Reflex. After rebate, the price will be under $150 for all four corners. And.. its a monotube shock. Wow.
