Putting on the rough country 2.5 and 285/60/20 duratracs. Whats everyone doing about the speedometer calibration. Talked to my dealer today and they said when they lift, or level trucks they don't recalibrate the speedo, but I call B.S. He also said if you calibrate it yourself with a programmer, it could void warranty because they don't know what was programmed, just know it was programmed. Anyone have any experience with this, thanks.
I used the Diablo Intune to fix my speedo
Its defiantly possible to do it, just wondering why the dealer can't or wont do it to customer trucks but will do it to dealer trucks before they sell them(im assuming they wont sell trucks with an uncalibrated speedo). Did you talk to the dealer about using the Diablo intune at all?
Nope. I don't use dealers for anything ever. Never had a good experience with a dealer of any brand (GM, VW, Acura, Audi, Jeep of Mazda). I won't even take my truck in for the 'free' oil changes, I'd rather pay for the oil and do it myself then have a dealer get their hands on my truck. I take all my vehicles to one mechanic thats a personal friend that I've known for 15 plus years when I'm really in a bind.
Wow. Seems to me that every new vehicle needs some sort of warranty work.
So you just pay your friend for all that and provide your own alternate transportation (loaner car/truck), and have your friend work on a $50000 proprietary computer chip?
Edited by austingta
I have multiple cars so I don't usually need a loaner. I've also never had a 'proprietary computer chip' problem in any car and every car I've ever owned has had some sort of programmer or chip tune done to it.
Some 'warranty claims' I've had over the years would include.
99' Audi A4 - Battery died and also killed the alternator. Towed it to my buddies indy shop, repaired, sent Audi the bill and was reimbursed. (40k miles on chip tune no issues)
'05 VW Jetta - HVAC lights went out. Took the car to the dealer, showed them what was going on, got a new HVAC unit free of charge and replaced it myself. (70k miles on a chip tune, no issues)
'07 Acura TL-S - Alternator went on me. Towed it to my buddies indy shop to diagnose, sent the bill to my dealer and they covered it. Also had a starter go bad on this car. Same process. (90k miles on programer, no issues)
'09 Jeep Commander - Starter went bad, towed it to the dealer and they agreed it was a starter. They gave me the part and I replaced it in the parking lot and drove home. (30k miles chip tune no issues)
'07 Trailblazer SS - Tire pressure sensors went bad. Given free replacements by the dealer, replaced at my indy shop. (50k miles chip tuned, no issues)
'07 Audi RS4 - 3rd gear syncro went bad. Had it replaced at my buddies shop, reimbursed by Audi. Power steering line was leaking, diagnosed by my buddies shop, parts provided free by the dealer, replaced them myself. (25k miles chip tune, 10k miles supercharged, no issues)
So no, I'm not worried about the programmer for my larger tires on this truck (to bring this back around to the topic at hand, sorry)
Edited by Flying Tomatoes
Is the leveling kit mess with the warranty I have the same problem with my 1014 silverado just to low in the front not good on a off road truck when your trying to hunt
I just installed a rough country 2" kit in my 2014 this morning. Both sides, the holes in the spacer were not drilled wide enough apart to match the spacing of the lower control arm. They were close, about 1\4 hole off, so was able make work, but what a pain. I called RC to make sure I ordered right part number, they said 1308 was correct for my truck. Has anyone else had this problem? I install RC level kit on my 2011 sierra and a Tahoe and had zero problems.
I too installed the RC 2 inch kit on my 2014 GMC Sierra and didn't have any issues with the hole spacing in the spacers or the length of the bolts as others have reported. I have about 2000 miles on the truck since the install and so far I'm very happy with the results and ride.
Sorry it's a 2014 silverado and does the kit mess with the warranty I'm new at this
It would only come into a warranty issue if you had a claim for something related to the suspension that might have been caused by the installation of this part. Premature wear-out of the ball joints comes to mind, since this is the same suspension as the 1500 GMT900 (2007-2013) and that model was reported by members here to be affected by these leveling kits.
So, no. Your overall truck warranty cannot be cancelled or voided due to modifying the truck. A claim may only be denied based on the effect your modification had on the claim you are making. If your electrical system malfunctions, a leveling kit would not play into a claim nor denial of a claim. But a claim for something like tires wearing weird might likely be denied by the dealer/GM.
Various dealers do their own modifications like lifting and leveling, big tires, brush guards, lights, etc.. The dealer usually provides their own warranty for such mods, independent of GM.
Edited by spurshot
Most of the time (not in all cases) when a dealer does a lift they sub it out to someone like 4 wheel parts or some other outfit. If the lift causes damage the GM warranty doesn't fix it. They go to the lift manufacturer or the outfit that accessorized the truck.
Question for people with a 2-2.5" level kit -> I'm looking to install the 2.25" Ready Lift Kit in the front and the 1" block kit in the rear and was wondering if 33's would have any rubbing issues with the OEM Chevy moulded mud flaps? Don't really want to install them and then have to remove them later because they require drilling. Any help would be great.
Jason
Jason
The 33" is the most commonly installed oversize diameter on this forum. I don't know how the mud flaps might be affected by O/S tires. I'm using a 12.50x33x18 on the factory rim and did so initially with no level/lift at all and had no rubbing at full steering lock using the OEM 18x8.5, 5.5" backspace rim. I currently run King shocks with about 1 1/2-2" lift in the front, with the same tire/wheels and have no rubbing. It's all about the combinations of wheel offset and tire size. I think the factory wheel offsets are close to ideal for facilitating the maximum width/dia tires you can stuff in the well at the "0" to minor lifts.
Edited by spurshot
Thanks spurshot. I've seen a couple of pictures on here of people with mud flaps and O/S tires and so far from what I can tell I think they would be alright. If you can run 33's without any leveling that makes me feel a little better about getting them installed.
    Smitty462
    Smitty462
  • Who's Online   4 Members, 0 Anonymous, 534 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
