Thanks spurshot. I've seen a couple of pictures on here of people with mud flaps and O/S tires and so far from what I can tell I think they would be alright. If you can run 33's without any leveling that makes me feel a little better about getting them installed.
Jason,
Just be mindful of the wheel offset.
Edited by spurshot
Stock wheels will not work with 33x12.50x20 . They are a +25 offset that puts the rim deep in the wheel well. You would need a 2 or 3 inch spacer and spacers will have problems down the road. This isn't my experience just what I have read. Maybe someone else can put in some knowledge about oem wheels and 33s. I have seen 295s. But but 33s on oem wheels.
Orly?
Orly?
My post was to say stock won't work.... any leveled truck will fit the tires.
That's leveled not stock...
Sunday bump
What offset are those rims?
I believe they are +0. The only other option is +18 but I think they stick out too much to be that high.
Edited by langston1726
I believe they are +0. The only other option would +18 but I think they stick too much to be that high.
Thanks! That's the offset I'm looking to get. I've see. Prices of your truck before but now I'm set on getting that offset.
Yea I think it's a good size. They poke out just enough. The 305/50s also compliment the stance. I'll probably go up to a 305/55 when these tires are done.
Ah, ok gotcha. [emoji106]
They look like the same offset as mine which are +14. Looking good!
Hi!
Need a bit of help. I had a leveling kit put on my 14 silvy and am running bfg all terrains. I like the look, however it rides like cement truck now. Over speed bumps the rear jumps hard and hits down hard. the front aswell if the speed bump is larger. im also bouncing all over the place on an uneven road.
im not quite sure the kit i got as i just went to a cap-it and they recommended one. maybe this was a bad idea? however I only asked for 2 inch front and an additional 1 inch for the rear. Based on reading this forum very little should be affected.
I also feel like it pulls to the right a bit aswell. alighnemnt was ok at first. not sure what would cause that.
I got a level as i was hoping to avoid these types of issues. Feel like i should have just wen with a true suspension lift now.
any ideas? the ride on these trucks was pretty nice and im disappointed it is so rough now. anyone else have this issue and maybe know how to help it? long shocks? better shocks? anything else to help?
Thanks, and sorry im pretty new to the lift kits.
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 811 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
