i had mine done at capital gmc in edmonton did the 4in lift lift costed $ 1097 plus 720 labor and 180 new wheel alignment
Woh, that is where I bought my truck from yo! And $875 is quoted from them too!
Edited by morrislee
There's a short list of things that are downsides.
  • Lower fuel economy at high speeds (low speeds shouldn't be affected much)
  • some have reported harsher ride (due to the steeper angle of the A-arms)
  • There were many reports of upper ball joint premature wear-outs with this same suspension in the GMT900 when 2.5" levels were installed (over limiting the ball joint angle) I'm sure we'll hear more of this on this model
  • The roll center is lifted and therefore body roll is increased in cornering/evasive maneuvering
  • lower checking account balance due to need for new tires, wheels, upper control arms, bull bars, etc., which all work to lower fuel economy more and lower your checking balance even further
As you know I plan on lifting with the Bilstein 5100 series adjustables or their new coilovers when they release. I will eventually as you did pick up a new pair of upper control arms to accommodate the lifted front end so I can extend life of the ball joints or at least I think it would help.
I'm still a little baffled by AZ's mpg on that trip.
^^^^Once you lift a truck and put bigger tires on you can't rely on the instant MPG gauge in your trucks DIC. It's tuned to factory equipment, and not that accurate in the first place. If AZ were to get a tune and correct the tire size, his instant MPG would improve but still not be completely accurate. Best bet is to hand calculate the MPG over a few tanks and find out what your actual MPG is. Winter blend gas is also to blame here, there are additive put in it to stop it from gelling in the cold…
My truck has 275/70/18's with a 2" level, it get's driven in the city a lot lately and says it's getting about 10MPG, but after hand calculating it, I'm actually getting 13-14MPG, which isn't bad for the amount of city driving I'm doing, with the Christmas holiday traffic, and with the winter blend gas that's in the tank… I can't wait to go on vacation in the new year and stretch the trucks legs, even with the winter blend I think it should get close to 20-22MPG… Before, when the truck was stock, on long trips with premium summer grade gas, I was getting 28+mpg on long trips. I knew the bigger tires were going to take a hit out of the fuel mileage, but the stock tires and clearance weren't going to get me to my fishing camp…
Edited by Daly
Guys, Hello, I am new here. I have read a lot of the posts regarding the RC 2" leveling kits.
I have '14 Denali 1500 without any suspension mods yet.
I really like the truck but I am not thrilled with the ride on my rough streets. Definitely due to the 20" rims.
Would love to put more rubber between the wheel and the road.
Don't really want to add a lift since I am short and I do use the bed of my truck.
Was thinking of adding the RC 2" leveling kit.
Not sure what that will allow me to get as far a tires.
Really like the Michelin LTX/MS2 tires. Had them on my last truck and they performed nicely.
However, they don't offer a 275/65/20. And I am not sure a 275/60/20 will give me what I am looking for.
Also, not sure the 2" leveling kit will allow me to get those tires anyway.
If I added the RC 2.5" with the lift, that should allow me to go to bigger tires. But that I think will put me too high.
If I did the 2.5" with the lift, I would love to go to a 280/65/20, do they even make that size?
So my question is this, can I get the 275/65/20 to fit if I do the RC 2" level kit?
If not, what do you suggest?
Thanks,
Jim
Jim,
That's a 34" tire. Some guys have gotten them to fit with a 275 width. It's all about wheel offset. You should check your clearances with the tires you have and calculate how much the new tire size will reduce those clearances. Have a friend turn the wheels to the stop and hold them there (engine running) while you measure or use the seatbelt to hold the steering wheel at the stops. Measure the clearances around the plastic well liner, the sway bar and whatever else is close. If a person is holding the steering wheel, be sure to tell them you'll be in the wheel well and your safety depends on them not moving the wheel. I used a seat belt.
You definitely can go up to a 285 width or even 295 if you go to a 33" diameter tire.
I agree with you all too. I get better mpg around town. My last fill up from a week around the city was 15/16 ish. We lift em and loose some mpg, but we get more looks and I am always bull shitting with people at the gas station about my truck. I think of I stayed around 70 mph I would of gotten better mpg. I also believe in premium fuel. I have been running it my truck since last week and it has increased my fuel economy by alot.
Jim,
Thanks Spurshot. I think I recall reading that you did the 2" level kit and added the Michelins. If I am correct, do you really think that improved the ride that much? As I stated, I am not really looking to make the truck taller, I just want more rubber between the rim and road. I want that for two reasons, first and foremost, the ride, I want a softer ride. I feel too much road. Second is curbs, want to get the rims away from curbs. But again the ride is my biggest concern.
Thanks and I like your dog. I am planning on selling my tonneau and putting on a cap. I want to get a lab and this truck is just too nice to put the dog in so I want a cap for it. Thinking of getting a LEER xq.
I have a question for the people on here who installed their lift kit themselves...if you install a kit yourself on a new truck will it affect your new vehicle warranty in any way?
Thanks,
Jason
Thanks,
Jason
If you have suspension, brake or tire problems, you betcha. GM has enough problems paying for legit warranty work.
i like the 4in lift but stock rims will not fit. factory offset is wrong rubs on the control arm . not sure with a 2in lift since i dont think they change the control arms?
I havent got it done yet. Many people did not specify if they had to change anything with 2.5 pad. The GM rep said with $875, no warranty voided BECAUSE no parts are taken out. I am guessing not touching the control arm.
i have full warranty since they did it at the dealership with the 4 in if your around edm i can show u the lift and how it rides
Actually yeah, if you dont mind, it is a good idea to know the difference if any :)
Putting on the rough country 2.5 and 285/60/20 duratracs. Whats everyone doing about the speedometer calibration. Talked to my dealer today and they said when they lift, or level trucks they don't recalibrate the speedo, but I call B.S. He also said if you calibrate it yourself with a programmer, it could void warranty because they don't know what was programmed, just know it was programmed. Anyone have any experience with this, thanks.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
